Help with FILEOPEN Command in AutoLISP
Hi everyone!
I'm working on an AutoLISP script to process multiple DWG files in AutoCAD. My goal is to open each file, perform certain operations with the SVAM-Todos command, and then return to the original file. I'm using the FILEOPEN command to activate each file, but I'm facing an issue: after executing FILEOPEN, I can't get back to the original drawing.
Here's my current code:
(defun c:SVAM-APP ()
(setq FILEPATH (getvar "dwgprefix"))
(setq FILES (vl-directory-files FILEPATH "*.dwg" 1))
(setq acadObject (vlax-get-acad-object))
(setq currentDoc (vla-get-ActiveDocument acadObject))
(foreach FILE FILES
(progn
(setq FILE_I_FILEPATH (strcat FILEPATH FILE))
(if (not (equal (strcase FILE) "SVAM.dwg"))
(progn
(command "FILEOPEN" FILE_I_FILEPATH)
(c:SVAM-Todos)
(vla-put-ActiveDocument acadObject currentDoc)
After running this code, I can't get back to the original file. Does anyone have any suggestions on how I can fix this or an alternative to the FILEOPEN command?
I appreciate any help or suggestions you can provide!
Thanks in advance.
