Help with FILEOPEN Command in AutoLISP
scottividal
Message 1 of 11
scottividal
Hi everyone!
I'm working on an AutoLISP script to process multiple DWG files in AutoCAD. My goal is to open each file, perform certain operations with the SVAM-Todos command, and then return to the original file. I'm using the FILEOPEN command to activate each file, but I'm facing an issue: after executing FILEOPEN, I can't get back to the original drawing.
Here's my current code:
(defun c:SVAM-APP ()
(setq FILEPATH (getvar "dwgprefix"))
(setq FILES (vl-directory-files FILEPATH "*.dwg" 1))
(setq acadObject (vlax-get-acad-object))
(setq currentDoc (vla-get-ActiveDocument acadObject))
(foreach FILE FILES
(progn
(setq FILE_I_FILEPATH (strcat FILEPATH FILE))
(if (not (equal (strcase FILE) "SVAM.dwg"))
(progn
(command "FILEOPEN" FILE_I_FILEPATH)
(c:SVAM-Todos)
(vla-put-ActiveDocument acadObject currentDoc)
After running this code, I can't get back to the original file. Does anyone have any suggestions on how I can fix this or an alternative to the FILEOPEN command?
I appreciate any help or suggestions you can provide!
Thanks in advance.
ASV
Replies (10)
Message 2 of 11
Sea-Haven
Dont know if this will work, but you can set the ITEM num of the dwg from within (vla-get-ActiveDocument acadObject)) you need though to be aware that the number may change as you add or close dwg's. Now where is that code. After adding a dwg you need to redo the activedocument as it now has more items.
I think I tried doing something similar and the rem line did not work.
(defun openblk (blkname / adocs)
(setq acDocs (vla-get-documents (vlax-get-acad-object)))
(vla-open acDocs blkname)
(vla-activate (vla-item acdocs 1))
;(vla-put-activedocument (vlax-get-acad-object) (vla-item acdocs 1))
Message 3 of 11
hmsilva
@scottividal
Autolisp is not really the right tool for your needs.
It is a single document application. Activating another document stops and autolsip program until the host document is activated again.
Using a script to cycle through the documents you need to run the (c:SVAM-Todos) and in the end return to the host document, It will probably be the best solution.
This post might give you some ideas
Hope this helps,
Henrique
Message 4 of 11
scottividal
Thank you for the suggestion, I've been researching scripts (with a bit of help from ChatGPT). And I understand a bit more, but I still can't solve my problem.
I understand that I should create a script that opens all the files in the folder and runs my Lisp routine on them. However, it's not clear to me if there's a way to automate the script to know the path of the folder. Also, I don't understand if I can include something like this code in the script.
; Script
 (setq files (vl-directory-files "." "*.dwg" 1))
(foreach file files
(if (/= file "EjecutarVigas.scr")
(progn
(command "_OPEN" (strcat (getvar "dwgprefix") file))
(command "_beams")
(command "_SAVE" "_YES")
(command "_CLOSE" "_YES") ) ) )
ASV
Message 5 of 11
Sea-Haven
A script would look something like this:
open dwg1
(load "yourlisp")
close Y
open dwg2
(load "yourlisp")
close Y
open dwg3
(load "yourlisp")
close Y
Message 6 of 11
hmsilva
; Script
(foreach file files
(progn
(command "_beams")
@scottividal change "X:/Your/File/Path/FileName.lsp" to the correct file path and name an try it.
;; Old Version of 'BrowseForFolder' by: Tony Tanzillo
(defun BrowseForFolder (Message / sh folder parentfolder folderobject result)
    (vl-load-com)
    (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
    (setq folder (vlax-invoke-method sh 'BrowseForFolder 0 Message 0))
    (vlax-release-object sh)
    (if	folder
	(progn
	    (setq parentfolder (vlax-get-property folder 'ParentFolder))
	    (setq FolderObject (vlax-invoke-method ParentFolder 'ParseName (vlax-get-property Folder 'Title)))
	    (setq result (vlax-get-property FolderObject 'Path))
	    (mapcar 'vlax-release-object
		    (list folder parentfolder folderobject)
	    (if	(/= (substr result (strlen result)) "\\")
		(setq result (strcat result "\\"))
		result
(defun c:demo (/ DirPath DwgFile DwgList Ofile Scrfile)
    (if	(setq DirPath (BrowseForFolder "Select directory to process all drawings."))
	(progn
	    (setq Scrfile (vl-filename-mktemp "test.scr"))
	    (setq Ofile (open Scrfile "w"))
	    (setq DwgList (vl-directory-files DirPath "*.dwg" 1))
	    (foreach Dwg DwgList
		(setq DwgFile (strcat DirPath Dwg))
		(write-line (strcat "_.open\r" (chr 34) DwgFile (chr 34) "\r") Ofile)
		(write-line (strcat "(load " (chr 34) "X:/Your/File/Path/FileName.lsp" (chr 34) ")\r") Ofile)
		(write-line "(c:SVAM-Todos)\r" Ofile)
		(write-line "_.qsave\r" Ofile)
		(write-line "_.close\r" Ofile)
	    (close Ofile)
	    (command "_.script" Scrfile)
    (princ)
Hope this helps,
Henrique
Message 7 of 11
scottividal
I hope this message finds you well. I am currently facing an issue with an AutoLISP script designed to process multiple DWG files consecutively. The script opens each drawing file, executes the SVAM-Todos command, adds a delay, and then moves on to the next file.
Here is the original script:
(defun c:demo (/ DirPath DwgFile DwgList Ofile Scrfile) (if (setq DirPath (BrowseForFolder "Select directory to process all drawings.")) (progn (setq Scrfile (vl-filename-mktemp "test.scr")) (setq Ofile (open Scrfile "w")) (setq DwgList (vl-directory-files DirPath "*.dwg" 1)) ;; Iterate over each drawing file (foreach Dwg DwgList (setq DwgFile (strcat DirPath Dwg)) ;; Write AutoCAD commands to the script file (write-line (strcat "_.open\r" (chr 34) DwgFile (chr 34) "\r") Ofile) (write-line "(c:SVAM-Todos)\r" Ofile) (write-line "(vl-cmdf 500) ; Add a delay of 500 milliseconds\r" Ofile) ;; Close the script file and execute it (close Ofile) (princ (strcat "Processing: " DwgFile "\n")) ;; Execute the script (if (= 0 (command "_.script" Scrfile)) (princ "Script executed successfully.\n") (princ "Error executing the script.\n") ) ) ;; Close the script file after processing all drawings (close Ofile) ) ) (princ) )
Despite several attempts, the script doesn't open the second drawing after processing the first one. I have already tried a few modifications, such as ensuring a new script file is created for each drawing, but the issue persists.
Has anyone faced a similar problem or could provide insights into what might be causing this behavior? Your assistance would be greatly appreciated.
Thank you in advance!
Best regards,
ASV
Message 8 of 11
paullimapa
share SVAM-Todos.lsp
Paul Li
IT Specialist
@The Office
Message 9 of 11
hmsilva
@scottividal try this one
		   (write-line "_.deley\r500\r" Ofile) ; Add a delay of 500 milliseconds\r"
	       (close Ofile)
	       ;|(if (= 0 (command "_.script" Scrfile))
;;;(close Ofile)
    (princ)
(= 0 (command "_.script" Scrfile) a command call will always return nil, this test will always be false...
The script file will stop because (vl-cmdf 500) will send to the command line only 500 and the result will be *Cancel* and stop the script...
To add a deley we need to use the command deley.
Hope this helps,
Henrique
Message 10 of 11
scottividal
I suspect that the issue might be related to the fact that the SVAM-Todos command at the end performs a save-as operation, potentially placing the modified file in a subdirectory. Could this be causing difficulties when trying to open the next drawing?
ASV
Message 11 of 11
paullimapa
Temporarily remove the Saveas and just do a Qsave see what happens. But do this on test dwgs only
Paul Li
IT Specialist
@The Office
