Properties of a non-AutoCAD element
jerzy.bajor
jerzy.bajor
I'm starting to use an Autocad overlay that has its own (non-Autocad) elements.
I tried '(vla-get-NumberOfBars...)' but it didn't help. An error occurred, which was to be expected.
I can view the properties of this element, but I can no longer download them for further processing.
Is there any way to get to this data.
The 'aliens' here are definitely: NumbersOfBars, Position, Multiplier, Diameter, Distance. DistanceStr.
Kent1Cooper
Does the (getpropertyvalue) function get it for you?  Read about it.
Or the other (vla) approach?
(vlax-get elem "NumberOfBars")
Kent Cooper, AIA
jerzy.bajor
Unfortunately, the getpropertyvalue function does not allow you to obtain this value.
The properties window, on the other hand, allows you to change it, so there is some way to get in and change its value.
EnM4st3r
have you tried  vlax-get-property?
(vlax-get-property (vlax-ename->vla-object (car (entsel))) "NumberOfBars")
Kent1Cooper
Is there a Forum somewhere for the overlay program you're using?  It seems like an overlay-program rather than an AutoCAD question.
Kent Cooper, AIA
Sea-Haven
Looks like a proxy object as suggested by Kent, can be hard or easy to get at.
jerzy.bajor
It worked.
To access the data, you had to run any command from this overlay.
It happened by accident.
