Help on creating a shortcut in AutocAD using MACRO VBA
I want to insert notes in my drawings ,using one simple click , by creating a customize tool bar button. How can I do it by writing a macro in VB. Please help me with the macro. I am attaching a snapshot for already done. In the snapshot red highlighted is the shortcut. When I click on it I get a note inserted in drawing. How can I do it for other notes?
Your toolbar can use lisp vba or just plain Autocad commands you dont need any special vba coding.
^c^c^pinsert notes3 pause 1 0
^c^c^p(command "-insert" "notes3 (getpoint) 1 0)
vba........
[code]
; handles block names with spaces in directory structure and name
(defun openblk (blkname / adocs)
(setq acDocs (vla-get-documents (vlax-get-acad-object)))
(vla-open acDocs blkname)
(vla-activate (vla-item acdocs 1))
[/code]
[code]
**PIPES
[PIPES]
[xxxSLD(SD201,SUBSOIL)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG201")
[\code]
Sorry I did not understand what you are trying to say.
Can you please give me step by step process
