Lost VLA- and VLAX-
Lost VLA- and VLAX-
devitg
Advisor Advisor
Message 1 of 14
Lost VLA- and VLAX-
devitg
My 2 acad  VLIDE version , 2008 and 2018 lost the VLA-nnn and VLAX-nnnn , what could be happen, there is any way to reload it
Maybe I did use CCleaner.
See following image
Replies (13)
Message 2 of 14
paullimapa
You may want to repair or reinstall AutoCAD.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 14
rkmcswain
Has the (vl-load-com) been executed before this screenshot?
And have you actually tried to run these functions? I've seen cases where the function highlighting fails.
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 14
devitg
Hi Pli, I did , at both version , but no way
Message 5 of 14
devitg
I test run (VL-LOAD-COM) (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT) ) ) and that's the answer ; error: no function definition: VLAX-GET-ACAD-OBJECT
Message 6 of 14
ВeekeeCZ
Well, I have a very recent experience with this too... it was quite sticky... and unfortunately can't recommend you anything useful.
- happend on acad 2015, w8.1
- reinstall 2015 - no activex
- upgrade to w10 (wanted to do that anyway), install 2018, still no activex
- get back to 8.1 (sound issues on w10), reset to factory w8.0, upgrade to w8.1, install 2018 - activex works!
- it feels good to have clean laptop
Kind of sad story... but  good luck to you anyway!!
Message 7 of 14
cadffm
@devitg
Clean uninstall, reboot, re-install should works.
(It's the only thing what will works)
If you have mutliple autodesk (autocad based products) perhaps it is need to un/re- install all.
You are not alone, search&find similar threads butt 99% reinstall is the solution (1% was another thing).
Sorry
Sebastian
Message 8 of 14
cadffm
For others
Autocad installations which are not uptodate, latest servicepacks/updates...
the install of serviceoacks/updates are one more a possible solution.
Sebastian
Message 9 of 14
devitg
Please give me  links
Message 10 of 14
cadffm
Which links do you ask for?
Sebastian
Message 11 of 14
devitg
Message 12 of 14
Ranjit_Singh
Browse to your Autodesk Desktop App and launch the app. It will show you the needed updates.Updates.jpg
Message 13 of 14
cadffm
I think i gave you hope where no hope is.
Try a clean uninstall of both (all) products again,
Install without anti virus with full admin rights and start the program as admin.
Sorry
Sebastian
Message 14 of 14
devitg
Don´t worry , thanks for it.
