Help Needed: AutoCAD LISP – Point Numbering with Block Attributes
javeed4teen
javeed4teen
Hello everyone,
I’ve prepared a LISP with some help, and I need an upgrade. Here’s what the current LISP does:
  • Takes the vertices of a selected polyline
  • Places a point at each vertex
  • Places a number (text) near each point
  • Prompts the user for text height and text offset
The problem is:
  • If two vertices are very close, it’s hard to tell which number belongs to which point.
  • I tried converting the point + number into a block with an attribute, so the number increments automatically for each vertex.
  • I want a solution where selecting the block selects both the point and the number, making it easy to see which number belongs to which point.
I’ve tried multiple approaches, but I keep running into issues:
  • Errors when creating the block programmatically
  • Attribute numbers not updating correctly
  • Blocks appearing larger than expected or containing the polyline itself
I’m looking for a robust solution where:
  1. The block contains both the point and a number attribute
  2. The number increments sequentially across all vertices and polylines
  3. The text offset is customizable
  4. A CSV with number, X, Y coordinates is exported
Has anyone successfully implemented something like this in AutoCAD using LISP? Any tips, example code, or guidance would be greatly appreciated.
Thanks in advance!
Sea-Haven
Have a look at this makes a block either a square or a circle and numbers them. Just add the "point" at the insertion point. Or use a "X". look at teh way the pline and circle are added.
