is there a lisp routine to extract Polyline length and width (both) to a table?
Message 1 of 13
Hi there,
I was wondering if anyone knows about a lisp routine to extract Polyline length and Global width (both) to a table?
I have found a lisp routine that only gives me the length in a table (see attachment - LAYLENGTH.lisp).
I want to get a quantity take off of many pipe diameters (width) and length that I drew with polyline command.
unfortunately I am not good in lisp Coding, is there a savvy in coding  that can modify it and include Global width, please?
Thanks.
John
Replies (12)
Message 2 of 13
ВeekeeCZ
So basically all you need is use the code 43 (width) instead of 8 (layer).
And maybe fix the entity filter to allow just LWPOLYLINE to select.
Message 3 of 13
AWESOME!!
Thanks BeeKeecz,
it works!
I was wondering if I can include also a code to include a misc object data property (MATERIAL) I added to PoLyline  (see Picture)
(I used commands: ADEDEFDATA to define object data and then ADEATTACHDATA to link the object data to the polyline)
I just don't know how to make this field shows in my table as well
thanks.
Message 4 of 13
ВeekeeCZ
Post the dwg sample of this polyline. Not sure if you can attach dwg -- if not, post it on some other cloud and post just a link.
Also not sure how the table should look like - just two columns, the 1st column the material, the 2nd would be the length as well?
There is this line in the code:
(setq lst (cons (mapcar '(lambda (a) (strcat "Col" (itoa (1+ (vl-position a (car lst)))))) (car lst)) lst))
change it to
(setq lst (cons '("Width" "Length") lst))
And search for "TITLE" is something you can do, right?
Message 5 of 13
BeeKeeCZ,
Basically, I would like to have a third column which includes the material.
It can be by adding the data Object property I linked to the polyline or somehow I could be able to fill out the pipe material
for each pipe (in the polyline properties) and using the code to export it in the table aswell.
Thanks.
see dwg attached.
Message 6 of 13
ВeekeeCZ
Hmm, you mean like sorted by width, then by material, then count the lenght? Like this?
Width     Material    Length
110           HDPE        25,5
63             HDPE         10
50             HT 50         30
If so, that's another story and the code needs to be rewritten...
Anyway, I don't have C3D in here so I can't help you right now.. maybe next week if anyone else does not step in... (assuming those functions work in C3D as well)
Message 7 of 13
You are exactly Right. BeeKeeCZ
that's What I would like to have.
It doesn't have to be in civil 3d it can be in plain Autocad. it will work for me.
Thanks BeeKeeCZ , whenever you get the chance I will really appreciate that
john
Message 8 of 13
ВeekeeCZ
Well, I do need C3D  🙂
Try the code. If you need different column sorting, see the notes in the code.
(vl-load-com)
(defun C:ListMaterial ( / *error* acdoc ss p i e a b ab d l)
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark acdoc)
  (defun *error* (msg)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*,*EXIT*"))
      (princ (strcat "\nError: " msg))
    (if
      (= 8 (logand (getvar 'undoctl) 8))
      (vla-endundomark acdoc)
    (princ)
  (if
    (and
      (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
      (setq p (getpoint "\nTable scale depend on annotation scale.\nSpecify table insert point: "))
    (progn
      (repeat
        (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i)))
              a (cdr (assoc 43 (entget e)))
              b (ade_odgetfield e "Pipes" "Material" 0)
              d (vlax-curve-getdistatparam e (vlax-curve-getendparam e))
        (or b (setq b ""))
        (setq ab (cons b a))
        (if
          (setq o (assoc ab l))
          (setq l (subst (list ab (+ (cadr o) d)) o l))
          (setq l (cons (list ab d) l))
      (setq l (vl-sort l '(lambda (a b) (< (cdar a) (cdar b))))
            l (vl-sort l '(lambda (a b) (< (caar a) (caar b))))
            l (mapcar '(lambda (x) (list (caar x) ; Material
                                         (cdar x) ; Size
                                         (cadr x))) ; Length
                      l))
      (insert_table l p)
  (*error* nil)
  (princ)
(defun insert_table (lst pct / tab row col ht i n space)
  (setq space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
        ht  (/ 2.5 (cond ((getvar 'cannoscalevalue)) (1.0)))
        pct (trans pct 1 0)
        n   (trans '(1 0 0) 1 0 T)
        tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 2 (length lst)) (length (car lst)) (* 2.5 ht) ht))
  (vlax-put tab 'direction n)
  (mapcar
    (function
      (lambda (rowType)
        (vla-SetTextStyle  tab rowType (getvar 'textstyle))
        (vla-SetTextHeight tab rowType ht)
   '(2 4 1)
  (vla-put-HorzCellMargin tab (* 0.14 ht))
  (vla-put-VertCellMargin tab (* 0.14 ht))
  (setq lst (cons '("Material" "Size" "Length") lst))
  (setq i 0)
  (foreach col (apply 'mapcar (cons 'list lst))
    (vla-SetColumnWidth tab i
      (apply
        'max
        (mapcar
          '(lambda (x)
             ((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht)))
              (textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))
          col
    (setq i (1+ i))
  (setq lst (cons '("MATERIAL LIST") lst))
  (setq row 0)
  (foreach r lst
    (setq col 0)
    (vla-SetRowHeight tab row (* 1.5 ht))
    (foreach c r
      (vla-SetText tab row col (if (numberp c) (rtos c) (vl-princ-to-string c)))
      (setq col (1+ col))
    (setq row (1+ row))
Message 9 of 13
braudpat
Hello Mr BeekeeCZ
I like your ListMaterial routine for ACAD MAP !
Thanks, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 10 of 13
ВeekeeCZ
Thank you @braudpat
Unfortunately I'm not the original author. @Anonymous posted here the code with no author reference, but you've made me to search for him - the code is pretty good!
So thanks @phanaem for the code! One of the versions was posted HERE by the author.
Hope you don't mind my modifications.
Message 11 of 13
Thanks BeeKeecz,
It was exactly what I was looking for.
Great job!!
Message 12 of 13
I want the lisp to add 3 columns (layer in first column ,width in second column ,length in third column)
Message 13 of 13
ppesquera
is there a version of this lisp that is compatible with autocad lt? unfortunately, ADEODGETFIELD is only exclusive to ACAD Map 3D
