Help... Need a lisp that create new layer group filter for selected block
designdistrict7
Message 1 of 14
designdistrict7
CAD/lisp experts , I need a help. can you write a lisp that can make selected block layer to a new layer group filter automatically. What I need if I select a block all layer used in that block will be add or create to a new layer group filter. So I can change layer color and properties easily from layer group filter without opening block editor.
Replies (13)
Message 2 of 14
ВeekeeCZ
Here's my routine... already posted somewhere.
Message 3 of 14
devitg
@ВeekeeCZ Hi, the
(initdia)
Is absent or lost
Message 4 of 14
designdistrict7
Thanks man, I don't have the words to express my gratitude, thanks 👍, may be you have the lisp that can change the dimension text to bylayer, dimension color not on bylayer inside block, if you have please share.
Thank you.
Message 5 of 14
designdistrict7
Hi, I dont understand ?
Message 6 of 14
devitg
@designdistrict7 Sorry , I read initdia, and guess it was user defun.
it is an AUTOLISP-ACAD command
initdia (AutoLISP)
Forces the display of the next command's dialog box
Supported Platforms: Windows and Mac OS
Message 7 of 14
ВeekeeCZ
@designdistrict7 wrote:
... may be you have the lisp that can change the dimension text to bylayer, dimension color not on bylayer inside block, if you have please share...
Better post a test file...
Message 8 of 14
designdistrict7
Message 9 of 14
designdistrict7
Please see sample file, set by layer not changing leader and dimension text color , if you have lisp for this please share
Message 10 of 14
ВeekeeCZ
Try this code. But... there is some issue with dim-color update if inside the block. You may still need to go inside the editor and run the routine from there. Still think it will speed up your job.
BTW also can try one of THESE  solutions... thought don't think it will help with the issues.
(vl-load-com)
(defun c:FixDimColors (/ s i e d n f fx)
  (defun fx (n / be o)
    (if (not (member n f))
      (progn
	(setq f  (cons n f)
	      be (tblobjname "BLOCK" n)
	(while (setq be (entnext be))
	  (if (= (cdr (assoc 0 (entget be))) "INSERT")
	    (fx (cdr (assoc 2 (entget be)))))
	  (setq o (vlax-ename->vla-object be))
	  ;(vl-catch-all-apply 'vla-put-layer (list o "0"))
	  (vl-catch-all-apply 'vla-put-color (list o 256))
	  (vl-catch-all-apply 'vla-put-textcolor (list o 256))
	  (vl-catch-all-apply 'vla-put-extensionLineColor (list o 256))
	  (vl-catch-all-apply 'vla-put-dimensionlinecolor (list o 256))
	  ;(vl-catch-all-apply 'vla-put-linetype (list o "bylayer"))
	  ;(vl-catch-all-apply 'vla-put-lineweight (list o -1))
	  ;(vl-catch-all-apply 'vla-put-plotstylee (list o "bylayer"))
  (if (and (setq s (ssget)) ;(list (cons 0 "INSERT"))))
	   (not (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))))
    (repeat (setq i (sslength s))
      (setq i (1- i)
	    e (ssname s i)
	    d (entget e)
	    f nil
	    o (vlax-ename->vla-object e))
      (if (= "INSERT" (cdr (assoc 0 d)))
	(fx (cdr (assoc 2 d))))))
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (vl-cmdf "_.regen")
  (princ)
Message 11 of 14
designdistrict7
Hi, I found one, but this one have no option to choose block, once it run entire drawing will change to bylayer , can you edit and add one option to select block or object.
(defun c:All2BYLA nil
(vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for obj block
(if (wcmatch (vla-get-objectname obj) "AcDb*Dimension,AcDb*Leader,AcDb*MLeader")
(foreach prop '(Color DimensionLineColor ExtensionLineColor LeaderLineColor LeaderColor TextColor)
(vl-catch-all-apply 'vlax-put-property (list obj prop acbylayer))
(vl-catch-all-apply 'vla-put-color (list obj acbylayer))
(princ)
(vl-load-com) (princ)
Message 12 of 14
designdistrict7
Thanks man, thanks for your time and sorry for asking again more helps
Message 13 of 14
ВeekeeCZ
Try this one, it should make it.
Message 14 of 14
designdistrict7
Nice... that is awesome.  Thanks man
