Selecting Object in Specific Layer with in a Boundary
jhunelb
jhunelb
Hi Experts,
I found this code here and I want to add a filter so that it will only select objects in specific layer.
(defun c:SWC (/ _pac add ss i temp i2)
;; Select Within Curve
;; Alan J. Thompson, 03.31.11
(vl-load-com)
(defun _pac (e / l v d lst)
(setq d (- (setq v (/ (setq l (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))) 100.))))
(while (< (setq d (+ d v)) l)
(setq lst (cons (vlax-curve-getPointAtDist e d) lst))
(princ "\nSelect closed curves to select object(s) within: ")
(if (setq add (ssadd)
ss (ssget '((-4 . "<OR")
(0 . "CIRCLE,ELLIPSE")
(-4 . "<AND")
(0 . "*POLYLINE")
(-4 . "&=")
(70 . 1)
(-4 . "AND>")
(-4 . "OR>")
(progn (repeat (setq i (sslength ss))
(if (setq temp (ssget "_CP" (_pac (ssname ss (setq i (1- i))))))
(repeat (setq i2 (sslength temp)) (ssadd (ssname temp (setq i2 (1- i2))) add))
(sssetfirst nil add)
(ssget "_I")
(princ)
Can you help me identify where to put this line:
'((-4 . "<or")(8 . "Layer01")(-4 . "or>"))
so I can only select object in this layer.
Thank you!
ВeekeeCZ
	     (if (setq temp (ssget "_CP" (_pac (ssname ss (setq i (1- i)))) '((8 . "Layer01"))))
And as matter of fact, you rather need the AND than OR. But since it works as implied, you don't need to spell it out. See not about <and ... and> HERE ...
Edit: Sorry, this makes much more sense.
jhunelb
Works like a charm!
Thanks man!
