Lisp doesn't works in normal AutoCad but not in AutoCad Mechanical
Hello everybody,
I am using 2 lisps to change the layers in a block to the layer of the block and the colors from objects in a block into the color "bylayer" from the block.
For example; If the color of the block (layer A) is grey, and the colors of the layers B and C in this block are yellow and red (not bylayer), they must become grey also.
If I use them in AutoCad 2016 - 2019, it isn't a problem. But if I use the lisp for changing colors in AutoCad Mechanical 2019 it doesn't work.
Could somebody help me with this?
Thank you
;**********Routine to change the color of a block**********
 (defun C:cbl (/ CNT CMD EN1 EN2 EG1 EG2 NAM SS1)
 (setq CMD (getvar "CMDECHO"))
 (setvar "CMDECHO" 1)
(load "ai_utils")
(setq blk_list (ai_table "block" 12)) ; no Xrefs or
 ; Xref dependents.
 (if (>= (getvar "maxsort") (length blk_list)) ; Alphabetize if greater
 (if blk_list (setq blk_list (acad_strlsort blk_list))) ; than maxsort.
(setq old_vp (getvar "cvport");save current viewport
 old_tile (getvar "tilemode");save current tilemode
 c_layer (getvar "layer")
 old_expert (getvar "expert"));save current layr
 (command "view" "s" "CBL")
 (ddslayer);save current layer settings
 (command "layer" "set" "0" "")
 (setvar "cmdecho" 1);debug
 (command "layer" "thaw" "*" "on" "*" "unlock" "*" "");thaw, on, unlock all
(setq rep 0)
 (repeat (length blk_list) ;process block list
 (BCBL (nth rep blk_list))
 (setq rep (+ 1 rep))
(COMMAND "change" "all" "" "p" "c" "bylayer" "")
;restore commands here
(command "zoom" "e")
 (ddrlayer) ;restore layer settings
 (command "layer" "set" c_layer "");set back to original layer
 (command "view" "r" "CBL")
 (setvar "attreq" old_attreq)
 (setvar "expert" old_expert)
 (prin1)
 (princ "\n\tLoaded CBL.LSP. Type CBL to begin.")
 (princ)
 ); end
;layer setting save routine
 (defun ddslayer ()
 (setq
 c_lay (getvar "clayer")
 lay_set_list nil
 layer_name (tblnext "layer" "T")
 (while layer_name
 (setq lay_set (get_set layer_name))
 (setq layer_list (append layer_list (list lay_set)))
 (setq layer_name (tblnext "layer"))
 ; BIT SET
 (defun BITSET (A B) (= (boole 1 A B) B))
 ; DXFGET
 (defun DXFGET (A B) (cdr (assoc A B)))
 ; Get layer settings
 (defun get_set (LAYER)
 (if LAYER
 (list
 (> (DXFGET 62 LAYER) 0) ;negative if off
 (bitset (DXFGET 70 LAYER) 1) ;set if frozen
 (bitset (DXFGET 70 LAYER) 4) ;set if locked
 (DXFGET 2 LAYER) ;layer name
(defun ddrlayer() ;layer restore routine
 (command "regenauto" "off")
 (setq rep 0)
 (command ".layer")
 (repeat (length layer_list)
 (setq t_layer (nth rep layer_list)
 l_name (cadddr t_layer)
 (command
 (if (car t_layer) "on" "off") l_name)
 (command
 (if (cadr t_layer) "freeze" "thaw") l_name)
 (command
 (if (caddr t_layer) "lock" "unlock") l_name)
 (command "")
 (princ)
 (prompt "\n\t\tStart with 'CBL'")(prin1)
 ;end
;---Loop through entities in the block---
 (defun BCBL (NAM)
(SETQ EN2 (cdr (assoc -2 (tblsearch "BLOCK" NAM)))
 (PRBLK EN2 NAM)
 (setvar "CMDECHO" CMD)
 (princ)
;*******Subroutine to change color and layer********
 (defun PRBLK (EN2 NAM)
 (setq CNT 0)
 (while EN2
 (setq CNT (1+ CNT)
 EG2 (entget EN2)
 EN2 (entnext (cdr (assoc -1 EG2)))
 (grtext -2 (strcat NAM " block entity # " (itoa CNT)))
 ;---Check color---
 (if (assoc 62 EG2)
 (setq EG2 (subst (cons 62 256) (assoc 62 EG2) EG2))
 (setq EG2 (append EG2 (list (cons 62 256))))
 (entmod EG2)
 ;---Set to layer 0---
(if (/= (cdr (assoc 8 EG2)) "0")
 (progn
 (setq EG2 (subst (cons 8 "0") (assoc 8 EG2) EG2))
 (entmod EG2)
 ;---Check for nested blocks---
 (if (= (cdr (assoc 0 EG2)) "INSERT")
 (progn
 (setq NM2 (cdr (assoc 2 EG2))
 EN3 (cdr (assoc -2 (tblsearch "BLOCK" NM2)))
 (PRBLK EN3 NM2)
 );endif
 ---Update all blocks in the drawing---
 (setq SS1 (ssget "X" (list (cons 2 NAM)));find all insertions of that block, if any
 CNT 0)
 (if SS1 (progn
 (setq C (- (sslength SS1) 1)) ; set counter
 (while (>= C CNT) ; while entities in the list
 (setq EN1 (ssname SS1 CNT))
 (setq CNT (1+ CNT))
 (entupd EN1)
 );end while C
 );progn
 );if SS1
 );defun
CodeDing
@Anonymous ,
Some people may not have the Mechanical vertical to test (like myself).
What does the command history say when you try to run it in AutoCAD Mechanical?
- Open a new Mechanical drawing.
- Load the Lisp.
- Try to run the Lisp command.
- Copy / Paste the command history of the drawing back here on the forums, please.
At first glance, is this file loading? Perhaps you need to add it to your support paths..
(load "ai_utils")
That would be useful for us to help further.
Best,
~DD
Sea-Haven
Found "Ai_utils" in c:/program files/autodesk/Autocad 2020/support/en-us
Hello @Sea-Haven and @CodeDing
I have found "ai_utils" in c:/Program Files/Autodesk/AutoCAD 2019/Support/en-us. The path C:/Program Files/Autodesk/AutoCAD 2019/Support is allready added to my support paths.
If I use Visual Lisp, I can not find an error. If I load the lisp, there are no errors.
If I use the CBL command right after loading the ai_utils, I get an error
Is it possible to combine this 2 lisps into 1 lisp or to edit my CBL lisp so I do not have to load the other lisp first?
CodeDing
@Anonymous ,
The error shown in your "cbl.png" image tells me that the "ai_utils" file cannot be found.
Try updating your code to this. If the file can not be found, you will need to check your support paths again.
(load "ai_utils" "Could not locate the 'ai_utils' file!!!")
Best,
~DD
Sea-Haven
2019/Support is allready added to my support paths. if it does not have the /en-us will not find, an undocumented is add .. two periods to 2019/Support.. this says look further down the directory.
@Sea-Haven
I think I have found the problem; I've added C:/Program Files/Autodesk/AutoCAD 2019/Support/en-us to my support file search path. After doing this I use the CBL command. The error doesn't appear but the lisp doesn't work how it should be.
If I restart AutoCad Mechanical 2019 again. The link to the /en-us is disappeared.
Maybe it's because I am working with on a network?
Some of my own commands doesn't work either. Overwrite the acad.pgp file doesn't work, and if I use the aliasedit command, my command "Q" is still "LAYISO" instead of "Qsave" and "CC" is still "CCONSTRAINTFORM" instead of "Copyclip". Maybe some of the commands which this lisp use aren't the right commands.
