Help joining newly created polylines
DC-MWA
DC-MWA
I'm working on a routine that calculates stairs and then draws a profile of the stairs.
I have calcs and the drawing of stair profile wotking. Problem is that each stair (riser and tread) are individual polyines.
I have attched a simplified version of this portion of the code.
As always, any input and assistance is greatly appreciated.
CodeDing
@DC-MWA,
Just responding on my phone, not at a computer. But by the looks of your lisp instead of using (command...) to create a polyline, I would recommend using (entmake).
Then while making a riser and tread, you can save your entity names in a list as you go and connect them later? I can look into this more tomorrow.
Best,
~DD
dbhunia
Try this....
(defun c:testst (/ getpt1 ss)
(setq ss (ssadd))
(setq getpt1 (getpoint "\nSelect start point: "))
(command ".pline" getpt1 (strcat "@6<90")(strcat "@11<0") "")
(ssadd (entlast) ss)
   (repeat 5
 	(command ".pline" "" (strcat "@6<90")(strcat "@11<0") "")
   );end repeat
(command "pedit" "M" ss "" "J" "0" "")
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
DC-MWA
Prefect. I was easily able to adapt your added code to my larger lisp. Works great and did't seem to slow anything down.
Thank you so much!!!!!!!
