LSP command create point cloud in Toolspace
Message 1 of 1
Hi there,
I am just new to the LSP programming. Currently we know how to manually create point cloud from XYZ text/CSV file.
Select "Create Point Cloud" in Toolspace, then follow the steps to select the XYZ file. But we want to use lsp to automatic this process. We was tried use create point command using LSP. But it not works which take about half day to finish run with the XYZ point data. The XYZ data also increase in the future as well. The lager the XYZ points are, the longer the run time is.
Please help with the LSP command to create point cloud.
Thanks for your information and help.
Ritchie
Replies (0)
