HELP: Autolisp for Creating Layers with Material Assigned
Need help to create a lisp code that will create a set of layers when prompted to select set (e.g. Set A contains layer 1, 2 and 3; Set B contains layer 4, 5 and 6; Set C contains layer 7, 8 and 9) and then within each layers it will have a material property (e.g. gold, copper, brass, etc). I am using ACAD2015.
Thank you.
SeeMSixty7
Create a LayerSetVariable something like
(setq LayerSets (list
                           (list "A" (list "1" "2" "3"))
                           (list "B" (list ""4" "5" "6"))
                           (list "C" (list "7" "8" "9"))
Then when your user or program needs Set A Simply use (assoc "A" or "B" or "C") to retrieve the layer list. Prompt the User for the Material and then append it to the layer name(s), then just create the layers. Hopefully that helps get you started
Good Luck
Thanks for the help! 🙂
