- Mute
- Permalink
- Report
I'm using this LSP file to get the hatch area, but I want to divide that value by 2.5. I look forward to your support for this matter
(defun c:DR nil (c:Areas2Field))
(defun c:Areas2Field ( / *error* _StartUndo _EndUndo acdoc acspc format pt ss ) (vl-load-com)
;; © Lee Mac 2011
(setq format "%lu6%qf1") ;; Field Formatting
(defun *error* ( msg )
(if acdoc (_EndUndo acdoc))
(or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **")))
(princ)
(defun _StartUndo ( doc ) (_EndUndo doc)
(vla-StartUndoMark doc)
(defun _EndUndo ( doc )
(if (= 8 (logand 8 (getvar 'UNDOCTL)))
(vla-EndUndoMark doc)
(setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
(if
(and
(ssget '((0 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE")))
(setq pt (getpoint "\nPick Point for Field: "))
(lambda ( ss fld ) (_StartUndo acdoc)
(vlax-for obj ss
(setq fld
(strcat fld "%<\\AcObjProp Object(%<\\_ObjId "
(LM:GetObjectID acdoc obj) ">%).Area>% + "
(vla-addMText acspc (vlax-3D-point (trans pt 1 0)) 0.
(setq fld
(strcat
(substr fld 1
(- (strlen fld) (if (< 1 (vla-get-Count ss)) 3 5))
" \\f \"" format "\">%"
(vla-delete ss) (_EndUndo acdoc)
(setq ss (vla-get-ActiveSelectionSet acdoc))
(if (< 1 (vla-get-Count ss)) "%<\\AcExpr " "")
(princ)
