AutoCad AutoLISP Functions layerstate-save
layerstate-save for autolisp cannot turn on the transparency.
From AutoCAD help:
(layerstate-save layerstatename mask viewport)
mask
An integer sum designating which properties in the layer state are to be restored.
1- Restore the saved On or Off value
2- Restore the saved Frozen or Thawed value
4- Restore the saved Lock value
8- Restore the saved Plot or No Plot value
16- Restore the saved VPVSDFLT value
32- Restore the saved Color
64- Restore the saved LineType
128- Restore the saved LineWeight
(layerstate-save "myLayerState" nil nil)
This will create a layer state with ticking all layer properties to restore including transparency.
Then, I tried below
(layerstate-save "myLayerState1" 1023 nil)
(layerstate-save "myLayerState2" 2047 nil)
These two will create a layer state with ticking all layer properties to restore except transparency.
How can I handle the layer state with transparency setting.
lena.talkhina
Welcome to the Autodesk Community @Anonymous !
Great to see you here on LISP forum.
Hope you will find a solution soon!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
