Has anyone gotten this error from this lisp code
thomas_huntFMPXR
thomas_huntFMPXR
Command: (setq dataLinks (vla-GetDataLinkManager (vla-get-Database doc)))
"; error: bad argument type: VLA-OBJECT nil " and "error: no function definition: VLA-GETDATALINKMANAGER"
(defun c:SD_SolarEdgeTable ( / acadApp doc modelSpace dataLinks dataLinkName dataLinkId excelFile insertionPt tableObj )
  (vl-load-com)
  ;; Constants for Data Link options
  (setq acDataLinkRangeAll 1)
  (setq acDataLinkUpdateAll 3)
  ;; Setup
  (setq acadApp (vlax-get-acad-object))
  (setq doc (vla-get-ActiveDocument acadApp))
  (setq modelSpace (vla-get-ModelSpace doc))
  ;; Ask user to select Excel file
  (setq excelFile (getfiled "Select Excel File" "" "xlsx" 0))
  ;; Exit if user cancels
  (if (not excelFile)
    (progn (princ "\nNo file selected. Exiting.") (exit))
  ;; Unique Data Link Name
  (setq dataLinkName "SolarEdgeTable")
  ;; Try to get existing Data Link
  (setq dataLinkId (vl-catch-all-apply 'vla-GetDataLink (list dataLinks dataLinkName)))
  ;; If it doesn't exist, create one
  (if (vl-catch-all-error-p dataLinkId)
    (setq dataLinkId (vla-AddExcelDataLink dataLinks dataLinkName excelFile "" acDataLinkRangeAll))
  ;; Ask for insertion point
  (setq insertionPt (getpoint "\nSpecify insertion point for the table: "))
  ;; Insert empty table; AutoCAD will resize it when updated
  (setq tableObj (vla-AddTable modelSpace (vlax-3d-point insertionPt) 1 1 5.0 20.0))
  ;; Attach Data Link to the table
  (vla-SetDataLink tableObj 0 0 dataLinkId)
  ;; Force table to update from Excel
  (vla-UpdateDataLink tableObj acDataLinkUpdateAll)
  (princ "\n Data-linked table inserted successfully.")
  (princ)
cadffm
doublepost?
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/having-problem-identifying-the-funct...
Let us discuss it in your first thread, we don't need two of them.
Sebastian
