Areas Displayed for Multiple Polylines Selected at Once
reception
Message 1 of 15
reception
Hi guys,
I really need someone to help me modify an existing LISP file (see attachment). As I need to show individual area on each enclosed polyline. The current LISP was a file I downloaded from another forum but they use 'square feet' instead of 'square meter'. Besides, I don't need a white background mask on the text. Preferably the area text would look exactly like the left image.
Appreciate all your kind help!
Kind Regards
Ashley
Replies (14)
Message 2 of 15
ВeekeeCZ
Possibly this
(vl-load-com)
(defun c:PlArea  (/ ados acsp ss e ptList Str txt p)
  (setq  acsp (vla-get-modelspace (setq adoc (vla-get-activedocument (vlax-get-acad-object)))))
  (vla-startundomark adoc)
  (if (setq ss (ssget ":L" '((0 . "*POLYLINE")
			     ;(8 . "A-AREA-BDRY")
			     (-4 . "&")
			     (70 . 1)(410 . "Model"))))
    (repeat (sslength ss)
      (setq e     (ssname ss 0)
	    sum   '(0 0)
	    verts (cdr (assoc 90 (entget e))))
      (setq ptList (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget e))))
      (foreach x ptList (setq sum (mapcar '+ x sum)))
      (setq Str (strcat (rtos (vlax-curve-getarea e) 2 0) "m2"))
      (vla-put-AttachmentPoint
	(setq txt (vla-addMText
		    acsp
		    (setq p (vlax-3d-point (mapcar '/ sum (list verts verts))))
		    0
		    Str))
	acAttachmentPointMiddleCenter)
      (vla-put-InsertionPoint txt p)
      (vla-put-Height txt 2.5)
      (ssdel e ss)
      )(princ "\0 Objects found:"))
  (vla-endundomark adoc)
  (princ)
Message 3 of 15
braudpat
Hello @reception
You can also try this beautiful routine "PolyArea_B" from Gilles (gile)
"PolyArea_B" runs on ARC,CIRCLE,ELLIPSE,POLYLINE 2D,SPLINE,MPOLYGON,REGION
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 15
Kent1Cooper
You can get it in superscript [the "Squared" option in the Symbol pull-down list in the Mtext editor]:
  (setq Str (strcat (rtos (vlax-curve-getarea e) 2 0) "m\U+00B2"))
Kent Cooper, AIA
Message 5 of 15
reception
Brilliant! Works perfect! Thank you!
Message 6 of 15
reception
Thanks BeekeeCZ! works well on most of the polylines. Seems didn't work on some irregular shaped polylines.
Message 7 of 15
reception
Thanks for the updates!!
Message 8 of 15
yousef-aboelala
Observer
Observer
Please, Can you edit this code to make the area value divided by 1000 ? and thanks in advance.
Message 9 of 15
Kent1Cooper
In your other post, you say your drawing unit is a millimeter and you want the area in square meters.  Would that not mean dividing by 1000000 instead?  There are 1000000 square millimeters in a square meter.
  (setq Str (strcat (rtos (/ (vlax-curve-getarea e) 1e6) 2 0) "m2"))
Change the 0 if you want decimal places in the result, not just whole square meters.
Kent Cooper, AIA
Message 10 of 15
yousef-aboelala
Observer
Observer
Yes i mean that you are right.
But i can't edit the lisp code i dont have any experience rly 🙂 can you edit it for me please ?
Message 11 of 15
yousef-aboelala
Observer
Observer
Perfect ! Thank you so much !
Message 12 of 15
Kent1Cooper
... i can't edit the lisp code .... can you edit it for me please ?
[Oops -- now I see you already did...] See my previous message, edited to include the one line that should be changed.
Kent Cooper, AIA
Message 13 of 15
pedromiguel3891
this is very good but can't get to change "precision 0.00 and m²"
Message 14 of 15
Moshe-A
@pedromiguel3891  hi,
try setting DIMZIN to 0
Moshe
Message 15 of 15
pedromiguel3891
@Moshe-A hey,
The problem is that within the lisp this area is sq ft. I am Portugal!
