grread pline make
grread pline make
diegolopezsilanes
grread pline make
diegolopezsilanes
hi, Im trying to use grread to see a preview of a pline with not so much luck
any help?
(defun c:PickList2()
(setq PT_LIST nil)
(while
(while
(setq PT (getpoint "\nPick a point: "))
; (command "borra" "lt" "")
(if (= PT_LIST nil)
(setq PT_LIST (list PT))
(setq PT_LIST (append (list PT) PT_LIST))
);while
(if (/= PT_LIST nil)
(progn
(command "_pline")
(foreach PT PT_LIST (command PT))
(command "")
);if
);while
(princ)
Kent1Cooper
I think you'd need more than (grread), but would also need to involve (grdraw) and/or (grvecs) functions.  Read about (grvecs) >in the AutoLisp Reference< -- it is probably just what you need, if you have a list of points.
It can also be done with an actual temporarily drawn Polyline -- I have rarely used these functions, but I made a routine that works that way, to draw a rectangle starting by picking its midpoint, called RectMidPoint.lsp, available >here<.  It's not a trivial exercise, but it should certainly be possible to do what you describe in similar fashion, if the (grvecs) approach doesn't suit for some reason.
Kent Cooper, AIA
CADaSchtroumpf
An exemple with grread, you can use at end, the list lst_pt for (entmake) a polyline.
((lambda ( / p1 p2 p3 ll pt_m px1 px2 key rad inc lst_pt pa1 pa2)
  (setq
    p1 (polar (getvar "VIEWCTR") 0 (* 0.5 (getvar "VIEWSIZE")))
    p2 (polar (getvar "VIEWCTR") pi (* 0.5 (getvar "VIEWSIZE")))
    p3 (polar (getvar "VIEWCTR") (* 2 pi) (* 0.5 (getvar "VIEWSIZE")))
    ll (list p1 p2)
    pt_m (getvar "VIEWCTR")
    px1 (polar pt_m (+ (angle p1 p2) (* pi 0.5)) (distance p1 p2))
    px2 (polar pt_m (- (angle p1 p2) (* pi 0.5)) (distance p1 p2))
  (princ "\nGive radius?: ")
  (while (and (setq key (grread T 4 0)) (/= (car key) 3))
    (cond
      ((eq (car key) 5)
        (redraw)
        (setq
          p3 (cadr key)
        (cond
          (pt_m
            (setq
              rad (distance pt_m p3)
              inc (angle pt_m p1)
              lst_pt '()
            (repeat 36
              (setq
                pa1 (polar pt_m inc rad)
                inc (+ inc (/ (* pi 2.0) 36.0))
                pa2 (polar pt_m inc rad)
                lst_pt (append lst_pt (list pa1 pa2))
            (grvecs lst_pt)
diegolopezsilanes
done this from Elpanov's code
its f
(defun c:vv () (c:VECTORS))
(defun c:VECTORS (/ PT PTLIST)
  ; Sequential choice of points
  ; by ElpanovEvgeniy
  ; (2005-10-19 17:59:01)
  ; (VECTORS)
  (setq d1 (getpoint "\n Specify the first point  ")
		d2 (getpoint "2nd pnt"))
  (setq d3 (v- d2 d1))
  (setq PTLIST (list
                 (setq PT (getpoint "\n Specify the first point  "))
               ) ;_  list
  ) ;_  setq
  (princ "\n Specify the following point  ")
  (princ)
  (while
    (setq PT
           (progn (while
                    (and (setq PT (grread 5))
                         (= (car PT) 5)
                    ) ;_  and
							; (if (= PT_LIST nil)
							; (setq PT_LIST (list PT))
							; (setq PT_LIST (append (list PT) PT_LIST))
                     (redraw)
                     (mapcar
                       (function
                         (lambda (x1 x2)
                           (grdraw x1 x2 6 5)
                         ) ;_  lambda
                       ) ;_  function
                       (cons (cadr PT) PTLIST)
                       PTLIST
                     ) ;_  mapcar
					 (mapcar
                       (function
                         (lambda (x1 x2)
                           (grdraw x1 x2 6 5)
                         ) ;_  lambda
                       ) ;_  function
                       (cons (cadr PT) d4)
                       d4
                     ) ;_  mapcar
                  ) ;_  while
                  (if (listp (cadr PT))
                    (cadr PT)
                  ) ;_  if
           ) ;_  progn
    ) ;_  setq
     (setq PTLIST (cons PT PTLIST))
	 (setq d4 (mapcar '(lambda (x) (mapcar '+ x d3)) PTLIST))
  ) ;_  while
  ; (setq d4 (mapcar '(lambda (x) (mapcar '+ x d3)) PTLIST))
  (make-lwpol PTLIST nil)
  (make-lwpol d4 nil)
) ;_  defun
unny for making multiple plines , but I cannot use ortho, so doesnt match
diegolopezsilanes
ill use this other kind for multi plines
;http://forums.augi.com/showthread.php?155444-Lisp-routine-for-a-new-command-to-draw-a-polyline-at-8-quot-wide-and-add-to-layer
(vl-load-com)
(defun c:PL8 (/ *error* acDoc layerName clayer plinewid)
  (defun *error* (msg)
    (and clayer (setvar 'clayer clayer))
    (and plinewid (setvar 'plinewid plinewid))
    (vla-endundomark acDoc)
    (cond ((not msg))							; Normal exit
	  ((member msg '("Function cancelled" "quit / exit abort")))	; <esc> or (quit)
	  ((princ (strcat "\n** Error: " msg " ** ")))			; Fatal error, display it
    (princ)
  ;; start undomark
  (vla-startundomark
    (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
  ;; layer check
  (if (not (tblsearch "layer" (setq layerName "-mylayer")))
    (vla-add (vla-get-layers acDoc) layerName)
  ;; get/set sysvars
  (setq clayer (getvar 'clayer))
  (setvar 'clayer layerName)
  (setq plinewid (getvar 'plinewid))
  (setvar 'plinewid 8.0)						;<-- be sure to adjust for your drawing units
  ;; draw the polyline
  (command "._pline")
  (while (= 1 (getvar 'cmdactive))
    (command pause)
  (*error* nil)
;kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
(defun c:XX () (c:PickList))
(defun c:PickList()
(setq PT_LIST nil)
(c:PL8)
(c:pts)
(princ)
(defun c:pts (/ pl );----------------------------------------
(setq n 5)
(and (setq pl (ssget "_L"))
     (foreach itm
	(setq PT_LIST (mapcar 'cdr
				     (vl-remove-if-not
				       '(lambda	(x)
					  (= (car x) 10)
				       (entget (ssname pl 0))
       (print itm)
(setq i 0)
(while (> n i)
(setq PT_LIST (mapcar '(lambda (x) (mapcar '+ x d3)) PT_LIST))
(make-lwpol PT_LIST nil)
(setq i (+ 1 i))
) ;_  while
  (princ)
;kkkkkkkkkkkkkk
