add a vector to a list of points
diegolopezsilanes
diegolopezsilanes
does anyone has a function to add a vector to a list of points?
john.uhden
Presuming your points list is in the format '((x1 y1 z1)(x2 y2 z2) etc.) and we call it PNTS, and we have one point as in (setq P '(10 20 0.0), then...
(setq PNTS (append PNTS (list P)))
Although the use of cons can be much faster, as in
(setq PNTS (reverse (cons p (reverse PNTS))))
John F. Uhden
Kent1Cooper
You don't say whether the order of the resulting list matters, i.e. where the added one ends up in relation to what's already in the list.  If it doesn't, just this will do:
(cons newpoint pointlist)
But I am a little curious about the terms "vector" and "points."  In AutoCAD, vectors are expressed in the same way as points, but do you mean something different by it?  Or do you, perhaps, mean you want to add a vector [such as an offset] to each point  in an existing list of points?  If that's what you need, this will do it:
(mapcar '(lambda (x) (mapcar '+ x YourVector)) YourPointList)
Kent Cooper, AIA
diegolopezsilanes
sorry, I was trying to sum the vector to the list of 2d points
Kent1Cooper
Is the vector also 2D?  If so, my edit-added suggestion should do.  If it's 3D, and you want the Z coordinate of the vector added to make the 2D points 3D, a little more would need to be done, but it's possible.
Kent Cooper, AIA
