Help fixing almost perfect auto publish lisp
I was searching for some time after the ultimate auto-publish lisp for my C++ project.
I needed something simple with minimum input and I finally found it but it has 2 problems
the output file is XPS (I need PDF), and I have no control over multi-sheet file or single sheet files...
can some one please help me fix it ?
(vl-load-com)
(defun Autopublish:StartReactor	()
  (or *AutopublishReactor*
      (setq *AutopublishReactor*
	     (vlr-docmanager-reactor
	       nil
		 (:vlr-documentbecamecurrent . Autopublish:DocumentBecameCurrent)
  (princ)
(defun Autopublish:DocumentBecameCurrent (rea doc)
  (if (and *AutopublishReactor* (= 1 (getvar 'automaticpub)))
    (prompt (strcat "\n[BlackBox] : AUTOMATICPUB = "
		    (itoa (setvar 'automaticpub 0))
  (princ)
(Autopublish:StartReactor)
maratovich
If you use C ++, then why use Lisp? Write the printing process in C ++.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Nick_Hall
Hi
You need to configure your AutoPublish options
See here (from AutoCAD 2018 help) http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-0A0DDEBA-5FF8-4ACF-A58F-589456535A53
To get to the dialog box, type OPTIONS, select the Plot and Publish tab, and clicking the Automatic Publish Settings button
Nick
