Getting Excelvalue of the next column(s) with one variable.
Message 1 of 22
Hi all,
This topic started on this link
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/error-on-getting-a-excelvalue/td-p/54...
Short explanation: I m trying to compare a variable with columnvalue's, get from the right match a row, and then use that rownumber to get all the next columns values.
If you look at the link above Henrique put a lisp together for the first columninteger, Now i  m trying to get the next columns, but i keep failing getting a right result. I know that
(1+ (1+ (vlax-get-property Cell 'Column)))
works for the next column but i can't seem to get it working.
I tried to made a subfunction val2 to extract from Column C. The Excel table from the link above isn't changed.
;;;                       --     Made by Subje       --
;;;                       --    Dieter Bevernage     --
;;;                       --        Abicon NV        --
;;;                       --         Belgium         --
;;;                       --    Many Thanks to ->->  --
;;;                       --   hmsilva - Henrique    --
;;;                       --  <-<-Made it possible   --
;;;                       --     Shared wisdom of    --
;;;                       --       Afralisp          --
;;;                       --      Terry Miller       --
;;;                       --        Lee Mac          --
;;;                       --        Hallex           --
;;;                       --     JefferyPSanders     --
;;;   Program Name: FindCells 1.01
;;;   First creation on 13/01/2015
;;;   Function: Know the value on Column B and find next the values on the next columns related to previeus value
;;;    $$          Revision History                                             $$
;;;    $$          Rev  By     Date    Description                              $$
;;;    $$           1    DB   15-01-13   Initial version                        $$
;;;    $$ Overvieuw functions:                                                  $$
;;;    $$ rtosr        $$
;;;    $$ ---Used to change a real number into a short real number string       $$
;;;    $$ Exceldossier                                                          $$
;;;    $$ ---Main function                                                      $$
;;;    $$ Sel-str                                                               $$
;;;    $$ ---Change type excelvalue                                             $$
(defun C:Doss(/ sel-str Exceldossier Val2)
  (vl-load-com)
  (defun sel-str (ExcelValue / rtosr)
;;http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/getexcel-lsp-changing-cell-color-of-c...
    (defun rtosr (RealNum~ / DimZin# ShortReal$)
      (setq DimZin# (getvar "DIMZIN")) (setvar "DIMZIN" 8)
      (setq ShortReal$ (rtos RealNum~ 2 8)) (setvar "DIMZIN" DimZin#)
      ShortReal$ );defun rtosr
    (setq ExcelValue
	   (cond
	     ((= (type ExcelValue) 'INT) (itoa ExcelValue))
	     ((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
	     ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
	     ((/= (type ExcelValue) 'STR) "")
	     );cond
	  );setq
;;;---Function to find value next to cel with same value as pronounced
  (defun Exceldossier (ExcelValue / xlfilename sheetName Excelapp xlSheet
    OpenExFile Excelfile MaxRange ExcData Datarange Projectname Column Cell)
;;;---Sheetname
    (setq sheetName "Dossiergegevens")
;;;---filelocation
    (setq xlfilename "R:\\Autodesk Standards\\test excel\\dossier.xlsx")
;;;---function to start excel
    (setq Excelapp (vlax-get-or-create-object "Excel.Application"))
;;;---if no Excel.exe exist errorprompt
    (if (not Excelapp)
      (progn
	(alert "Can't start Excel")
	(exit)
;;;---Put excel invisible
    (vla-put-visible Excelapp :vlax-false)
;;;---ignore alerts excel
    (vlax-put-property Excelapp 'DisplayAlerts :vlax-False)
;;;---Open file with excel
    (setq Excelfile (vl-catch-all-apply 'vla-open
		      (list (vlax-get-property Excelapp "WorkBooks") xlfileName)))
;;;---look for sheets
    (setq xlSheet (vl-catch-all-apply 'vlax-get-property
		    (list (vlax-get-property Excelfile "Sheets") "Item" sheetName)))
;;;---Make the selected worksheet active
    (vlax-invoke-method xlSheet "Activate")
;;;--- cellrange in sheet
    (setq MaxRange (vlax-get-property (vlax-get-property xlSheet 'Cells) "range" "B2:B20"))
 ;; to get the ExcData as a list of strings
    (vlax-for x MaxRange
      (setq ExcData (cons (sel-str (vlax-variant-value (vlax-get-property x 'Value))) ExcData)))
    (setq ExcData (reverse ExcData))
 ;; to get the next column cell   Column projectname
	(if (= (sel-str (vlax-variant-value (vlax-get-property x 'Value))) ExcelValue)
	  (progn
	    (setq Cell x)
	    (setq Projectname (sel-str (vlax-variant-value
					 (vlax-get-property
					   (vlax-variant-value
					     (vlax-get-property
					       'Item
					       (vlax-get-property Cell 'Row)
					   'Value
	      );setq
	    cell
	  );progn
	);if
      );vlax for
;; If cellvalue has no value or existing go to the next errorphrase
    (if Projectname
      Projectname
      (princ "projectname not found!")
(defun Val2 (Cell /  Definition)
    (setq Definition (sel-str (vlax-variant-value
					 (vlax-get-property
					   (vlax-variant-value
					     (vlax-get-property
					       'Item
					   'Value
;;; aks for projectnumber; Get string?
  (while (/= "" (setq ExcelValue
		       (getstring "\nWhat's the projectnumber? [ Examples: 5020 or VD655 ]:")))
    (setq Projectname (Exceldossier ExcelValue))
    (Setq Definition (Val2 Cell))
    (princ (strcat "\n The value of address " ExcelValue " is: "))
    (princ Projectname )
    (princ Definition )
  (princ)
Replies (21)
Message 21 of 22
Hi henrique,
So i look at everything and now i understand that it won't work without using same property names, It went out of my reach when the first row was linked ;). I linked the same lisp as yours but i analysed some expression so i could understand how it works. Next thing i gonna do is adjust the excel and check the custombox.
Then i will try to expand a bit more to dcl- with more attributes. But my primary objective is understanding this lisp. I analyzed partially the lisp, Most in Function DEMO so could you check if i got the explanation right :).
Also you say you did a strcat on Lst. Is that a way to check thinks out, how it's goes? Can you give some Example. I think i would be better if i could upgrade my control on expression and functions.
And as always, good job Henrique. you're flawless.
Big Thanks.
Dieter
Message 22 of 22
hmsilva
Hi Dieter,
you got the explanation right!!! Smiley Happy
The 'strcat' was a typo, I wanted to write 'strcase', to get the properties in excel in upercase...
Henrique
