Message 1 of 22
08:28 AM
Hi all,
This topic started on this link
Short explanation: I m trying to compare a variable with columnvalue's, get from the right match a row, and then use that rownumber to get all the next columns values.
If you look at the link above Henrique put a lisp together for the first columninteger, Now i m trying to get the next columns, but i keep failing getting a right result. I know that
(1+ (1+ (vlax-get-property Cell 'Column)))
works for the next column but i can't seem to get it working.
I tried to made a subfunction val2 to extract from Column C. The Excel table from the link above isn't changed.
;;; ----------------------------- ;;; -- -- ;;; -- Made by Subje -- ;;; -- Dieter Bevernage -- ;;; -- Abicon NV -- ;;; -- Belgium -- ;;; -- -- ;;; -- Many Thanks to ->-> -- ;;; -- hmsilva - Henrique -- ;;; -- <-<-Made it possible -- ;;; -- -- ;;; -- Shared wisdom of -- ;;; -- Afralisp -- ;;; -- Terry Miller -- ;;; -- Lee Mac -- ;;; -- Hallex -- ;;; -- JefferyPSanders -- ;;; -- -- ;;; ----------------------------- ;;; Program Name: FindCells 1.01 ;;; First creation on 13/01/2015 ;;; Function: Know the value on Column B and find next the values on the next columns related to previeus value ;;; $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ ;;; $$ $$ ;;; $$ Revision History $$ ;;; $$ Rev By Date Description $$ ;;; $$ $$ ;;; $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ ;;; $$ $$ ;;; $$ 1 DB 15-01-13 Initial version $$ ;;; $$ $$ ;;; $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ ;;; $$ $$ ;;; $$ Overvieuw functions: $$ ;;; $$ $$ ;;; $$ rtosr $$ ;;; $$ ---Used to change a real number into a short real number string $$ ;;; $$ $$ ;;; $$ Exceldossier $$ ;;; $$ ---Main function $$ ;;; $$ $$ ;;; $$ Sel-str $$ ;;; $$ ---Change type excelvalue $$ ;;; $$ $$ ;;; $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ (defun C:Doss(/ sel-str Exceldossier Val2) (vl-load-com) (defun sel-str (ExcelValue / rtosr) ;;http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/getexcel-lsp-changing-cell-color-of-c... (defun rtosr (RealNum~ / DimZin# ShortReal$) (setq DimZin# (getvar "DIMZIN")) (setvar "DIMZIN" 8) (setq ShortReal$ (rtos RealNum~ 2 8)) (setvar "DIMZIN" DimZin#) ShortReal$ );defun rtosr (setq ExcelValue (cond ((= (type ExcelValue) 'INT) (itoa ExcelValue)) ((= (type ExcelValue) 'REAL) (rtosr ExcelValue)) ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue)) ((/= (type ExcelValue) 'STR) "") );cond );setq ) ;;;---Function to find value next to cel with same value as pronounced (defun Exceldossier (ExcelValue / xlfilename sheetName Excelapp xlSheet OpenExFile Excelfile MaxRange ExcData Datarange Projectname Column Cell) ;;;---Sheetname (setq sheetName "Dossiergegevens") ;;;---filelocation (setq xlfilename "R:\\Autodesk Standards\\test excel\\dossier.xlsx") ;;;---function to start excel (setq Excelapp (vlax-get-or-create-object "Excel.Application")) ;;;---if no Excel.exe exist errorprompt (if (not Excelapp) (progn (alert "Can't start Excel") (exit) ) ) ;;;---Put excel invisible (vla-put-visible Excelapp :vlax-false) ;;;---ignore alerts excel (vlax-put-property Excelapp 'DisplayAlerts :vlax-False) ;;;---Open file with excel (setq Excelfile (vl-catch-all-apply 'vla-open (list (vlax-get-property Excelapp "WorkBooks") xlfileName))) ;;;---look for sheets (setq xlSheet (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property Excelfile "Sheets") "Item" sheetName))) ;;;---Make the selected worksheet active (vlax-invoke-method xlSheet "Activate") ;;;--- cellrange in sheet (setq MaxRange (vlax-get-property (vlax-get-property xlSheet 'Cells) "range" "B2:B20")) ;; to get the ExcData as a list of strings (vlax-for x MaxRange (setq ExcData (cons (sel-str (vlax-variant-value (vlax-get-property x 'Value))) ExcData))) (setq ExcData (reverse ExcData)) ;; to get the next column cell Column projectname (vlax-for x MaxRange (if (= (sel-str (vlax-variant-value (vlax-get-property x 'Value))) ExcelValue) (progn (setq Cell x) (setq Projectname (sel-str (vlax-variant-value (vlax-get-property (vlax-variant-value (vlax-get-property (vlax-get-property xlSheet 'Cells) 'Item (vlax-get-property Cell 'Row) (1+ (vlax-get-property Cell 'Column)) ) ) 'Value ) ) ) );setq cell );progn );if );vlax for ;; If cellvalue has no value or existing go to the next errorphrase (if Projectname Projectname (princ "projectname not found!") ) ) (defun Val2 (Cell / Definition) (setq Definition (sel-str (vlax-variant-value (vlax-get-property (vlax-variant-value (vlax-get-property (vlax-get-property xlSheet 'Cells) 'Item (vlax-get-property Cell 'Row) (1+ (1+ (vlax-get-property Cell 'Column))) ) ) 'Value ) ) ) ) ) ;;; aks for projectnumber; Get string? (while (/= "" (setq ExcelValue (getstring "\nWhat's the projectnumber? [ Examples: 5020 or VD655 ]:"))) (setq Projectname (Exceldossier ExcelValue)) (Setq Definition (Val2 Cell)) (princ (strcat "\n The value of address " ExcelValue " is: ")) (princ Projectname ) (princ Definition ) ) (princ) )
