Change layercolors to associated entity colors
Message 1 of 11
Hello!
I have several drawings with entities placed in differend layers. The layercolors are all white. All the entities have colors (so, not bylayer...). I want the different layercolors (white or whatever...) to change to the same color of each associated entity. So layer A is color white. The entity on layer A is red. I run a script/lisp and voila. Layer A is now color red. Entity on layer A stays red (and the color of course is now bylayer...).
Can someone help me?
Luis
Replies (10)
Message 2 of 11
Lee_Mac
Quickly written, but should perform as required:
(defun c:laycolfix ( / doc lay lst lyn )
    (setq doc (vla-get-activedocument (vlax-get-acad-object))
          lay (vla-get-layers doc)
    (vlax-for blk (vla-get-blocks doc)
        (if (= :vlax-false (vla-get-isxref blk))
            (vlax-for obj blk
                (if (not (member (vla-get-color obj) '(0 256)))
                    (progn
                        (if (not (member (setq lyn (vla-get-layer obj)) lst))
                            (progn
                                (vla-put-color (vla-item lay lyn)(pp (vla-get-color obj)))
                                (setq lst (cons lyn lst))
                        (if (vlax-write-enabled-p obj)
                            (vla-put-color obj acbylayer)
    (princ)
(vl-load-com) (princ)
Message 3 of 11
Lineabove
Hi Lee.
Question please.
When I run this lisp I get the following message...
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Mel
Message 4 of 11
Lee_Mac
Are you sure that error message stems from my code? Since my code does not define a local *error* function, nor does it make any call to the command function.
Lee
Message 5 of 11
Lineabove
Hi Lee,
Not so sure, however I have attached a very simple drawing that if I run your lisp on, I will receive that error message.
If it matters, I am using AutoCAD Architecture 2015.
Any comments would be appreciated.
Message 6 of 11
Hi Lee,
Sorry for the late respons. Thanks for your reply/solution! Again, much appreciated!
I tried your lisp and the following error apears in de screen after loading the it:
; error: no function definition: PP
I tried both in Autocad 2012 and 2015. See also the attachment example dwg
Thanks!
Luis
Message 7 of 11
Lee_Mac
Apologies, I had left a test function where it shouldn't be - please try the following:
            (vlax-for obj blk
                    (progn
                            (progn
                                (vla-put-color (vla-item lay lyn) (vla-get-color obj))
    (princ)
Message 8 of 11
Lineabove
Thank you Lee.
I appreciate your contribution to this newsgroup.
Works perfect.
Message 9 of 11
Lee_Mac
Excellent to hear - you're very welcome Lineabove Smiley Happy
Message 10 of 11
Thank you also Lee! Tried it first thing in the morning and, as mentioned before, it works! Smiley Happy
Message 11 of 11
Lee_Mac
Excellent to hear Peter - I hope it saves you some time.
Lee
