How much does the LT upgrade cost compared to say Bricscad Lite ? Which is perpetual and not yearly.
I am sure we will see lots jump to LT 2024 just for the lisp.
What about this running Autocad from Excel. Can anyone test ?
Sub Opendwg()
Dim acadApp As Object
Dim acadDoc As Object
'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If acadApp Is Nothing Then
Set acadApp = CreateObject("AutoCAD.Application")
acadApp.Visible = True
'Check (again) if there is an AutoCAD object.
MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
Exit Sub
On Error GoTo 0
'If there is no active drawing create a new one.
Set acadDoc = acadApp.ActiveDocument
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
On Error GoTo 0
'Check if the active space is paper space and change it to model space.
If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding
End Sub
Also the other LT to Excel is probably not possible as need (vlax-get-object "Excel.Application") or (vlax-get-or-create-object "excel.Application") as it mentions not available.
