Get ready for AutoCADLT2024 users...
pendean
Community Legend Community Legend
pendean
Community Legend
Community Legend
dmfrazier
Interesting....
Sea-Haven
How much does the LT upgrade cost compared to say Bricscad Lite ? Which is perpetual and not yearly.
I am sure we will see lots jump to LT 2024 just for the lisp.
What about this running Autocad from Excel. Can anyone test ?
Sub Opendwg()
    Dim acadApp As Object
    Dim acadDoc As Object
 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
    On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application")
    If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    End If
    'Check (again) if there is an AutoCAD object.
        MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
        Exit Sub
    End If
    On Error GoTo 0
    'If there is no active drawing create a new one.
    Set acadDoc = acadApp.ActiveDocument
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add
    End If
    On Error GoTo 0
    'Check if the active space is paper space and change it to model space.
    If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
        acadDoc.ActiveSpace = 1     '1 = acModelSpace in early binding
    End If
 End Sub
Also the other LT to Excel is probably not possible as need (vlax-get-object "Excel.Application") or (vlax-get-or-create-object "excel.Application") as it mentions not available.
