Get polyline length total by layer in table
paliwal222
Message 1 of 28
paliwal222
Dear all,
Need a lisp  or lisp customization for total length of polyline by layer and color display also.
here i attached a  drawing and lisp also.
I will very thankful for getting help.
Replies (27)
Message 21 of 28
baksconstructor
Message 22 of 28
caominhnguyen85
Yes Sir , exactly like this . Could you provide that autolisp . Thank you !
Message 23 of 28
baksconstructor
This is not lisp, this is another add-on.
Since this forum thread does not allow links to free add-ons, search for it yourself by the name "MyPropertiesCAD"
Here's how to set it up for your case.
And then get the table.
Message 24 of 28
caominhnguyen85
Great ! Thank you very much for you help ! I will try it .
Message 25 of 28
caominhnguyen85
Could you please help me again Sir ?  I have already set-up as per your tutorial  . Then when I pick create table --> click to the "Select and get objects" then choose some lines but it said  "0 found"
Message 26 of 28
baksconstructor
Before this, you need to tell the program that this is your desired object.
You need to select all your segments or polylines or other objects.
Then open the properties window.
In the properties window, in the parameters, specify the name.
For example, for all objects at once, you can write the name "Lines" or "This is mine"
Then the object will be marked that it needs to be processed.
The main function of the program is to give any properties to any object. And if there are properties, then this is the desired object and you can get additional data from it.
After this, you can get a table for these objects.
Message 27 of 28
caominhnguyen85
FINALLY, I DID IT JUST AS I WANTED. THANK YOU AGAIN FOR YOUR DEDICATED GUIDANCE. I DIDN'T EXPECT THIS TO BE SO USEFUL. HOPEFULLY, IT'S FREE.
Message 28 of 28
3arizona
I hate to open this thread again but how can i change the Header extraction? At the moment its picking up the drawing name and i want to change it to Linear Feet.
thank you for your time
