Lisp to export lines colors and texts beside them to excel
hythamthelove
Message 1 of 24
hythamthelove
Hello everyone,
i want a lisp to export all selected lines colors and also export texts beside them to excel. You can find below photos of the lines and texts in autocad and the table i want in excel, also DWG file will be attached for reference. If it is hard to get texts beside the lines, i could move texts to be in the line itself.
Thanks in advance
Replies (23)
Message 2 of 24
ВeekeeCZ
What is "beside" them. Post some cut-off from real dwg. Not a "legend" if that is.
And save that excel file with that example to *.csv and post it too.
Message 3 of 24
hythamthelove
actually this is exactly the case, i have some lines and some texts next to it (this is not a legend or something this is the actual case) as attached in the dwg, but of course they are not 3 lines and 3 texts only they are alot i am just bringing a sample but all of them are in the same format. The excel or csv i want is as attached here
Message 4 of 24
ВeekeeCZ
post the csv
Message 5 of 24
hythamthelove
here it is
Message 6 of 24
ВeekeeCZ
Here you go. Not as simple as you might think.
(vl-load-com)
(defun c:ExportToCsv ( / *error* f LM:ACI->RGB s i e d st sl)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if f (close f))
    (princ))
  ;; Lee Mac ;; http://www.lee-mac.com/colourconversion.html#truaci
  (defun LM:ACI->RGB ( c / o r )
    (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
      (progn
	(setq r (vl-catch-all-apply '(lambda ( ) (vla-put-colorindex o c) (list (vla-get-red o) (vla-get-green o) (vla-get-blue o)))))
	(vlax-release-object o)
	(if (vl-catch-all-error-p r)
	  (prompt (strcat "\nError: " (vl-catch-all-error-message r)))
	  r))))
  (if (setq s (ssget '((0 . "LWPOLYLINE,LINE,*TEXT"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    d (entget e))
      (if (wcmatch (setq y (cdr (assoc 0 d))) "*TEXT")
	(setq st (cons (cons (caddr (assoc 10 d)) (getpropertyvalue e (if (= "TEXT" y) "StringText" "Text"))) st))
	(setq sl (cons (cons (caddr (assoc 10 d)) (if (wcmatch (setq c (getpropertyvalue e "Color")) "*`,*")
						    c
						    (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," (itoa x))) (LM:ACI->RGB (atoi c)))) 2)))
		       sl)))))
  (if (and st sl
	   (setq f (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-Export.csv") "a"))
	   (write-line "Color,Text" f)
    (foreach e (vl-sort sl '(lambda (e f) (> (car e) (car f))))
      (write-line (setq l (strcat "\"" (cdr e) "\","
				  (vl-string-trim " " (cdar (vl-sort st '(lambda (g h) (< (abs (- (car e) (car g))) (abs (- (car e) (car h)))))))))))
      (write-line l f)))
  (*error* "end"))
Message 7 of 24
hythamthelove
thank you for your efforts really appreciated. I tried the lisp but it gives me this error "ADS request error" do you know how to solve this problem ?
Message 8 of 24
ВeekeeCZ
Does it fail on the file you posted? No issues here.
If on a different file, you need to post it. I won't be able to fix it without seeing the issue.
Message 9 of 24
calderg1000
Regards @hythamthelove
To start, here is my proposal, tested in the example file. Please select only the polylines
(vl-load-com)
(defun c:sst (/ f of s sn svn p1 p2 tx tf)
  (setq f  (getfiled "\nEnter name File:" "" "csv" 1)
        of (open f "w")
  (setq s (ssget '((0 . "lwpolyline"))))
    (setq sn  (ssname s (setq i (1- i)))
          svn (vlax-ename->vla-object sn)
          ct  (vla-get-truecolor svn)
    (setq p1 (cdr (assoc 10 (entget sn)))
          p2 (polar p1 0 5400)
    (setq tx (ssget "_f" (list p1 p2) '((0 . "*text")))
          tf (substr (cdr (assoc 1 (entget (ssname tx 0)))) 7)
    (write-line (strcat (col ct) ";" tf) of)
  (close of)
(defun col (c)
    (apply 'strcat
           (mapcar '(lambda (x) (strcat (itoa (vlax-get c x)) ","))
                   '(red green blue)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 10 of 24
hythamthelove
Thank you for your effort, i tried it several times, it sometimes works and sometimes gets no values for the lines.
Here it the file i test on for reference
Message 11 of 24
hythamthelove
i actually figured out the problem, when the color is red or yellow or any of these colors the lisp stuck, otherwise it works great. Here is the file i use
Message 12 of 24
ВeekeeCZ
Good! I'll fix that tomorrow.
Message 13 of 24
calderg1000
Dear @hythamthelove
I made some adjustments, you had texts that were not in the selection line and with different configuration.
Tested on the new file provided. Please select only the polylines by 2 points (Fence) from top to bottom.
(vl-load-com)
(defun c:sst (/ f of s ps1 i sn svn ct p1 p1b p2 p2b tx tt ltx tf)
  (princ "\nSelect polylines by FENCE:")
        of (open f "w")
  (setq osm (getvar 'osmode))
  (setvar 'osmode 0)
  (if
    (setq s (ssget "_f"
                   (list (setq ps1 (getpoint "\nPick Point 1:"))
                         (getpoint "\nPick Point 2:" ps1)
     (progn
       (setq i 0)
       (repeat (sslength s)
         (setq sn  (ssname s i)
               p1b (list (car p1) (- (cadr p1) 250))
               p2b (list (car p2) (+ (cadr p2) 250))
         (setq tx  (ssget "_c" p1b p2b '((0 . "*text")))
               tt  (cdr (assoc 1 (entget (ssname tx 0))))
               ltx (vl-string->list tt)
         (setq i (1+ i))
         (if (= (nth 0 ltx) 92)
           (setq tf (substr tt 7))
           (setq tf tt)
       (close of)
  (setvar 'osmode osm)
  (princ)
(defun col (c)
    (apply 'strcat
                   '(red green blue)
Carlos Calderon G
Message 14 of 24
Sea-Haven
Another method is just select all lines and text, and use a sorted Y value to make pairs of a line and text. This would get round the problem of the offset to text varies.
Will add "to do list" has a few now.
Message 15 of 24
hythamthelove
thank you for your reply. i will give it a try thank you so much
Message 16 of 24
hythamthelove
ok waiting for you. thanks for your help
Message 17 of 24
ВeekeeCZ
Ok, thx. Thy the code below, it should be ok.
Anyway, interestingly my original code works fine at both my stations. Just for the future, would you post a command-line listing of returns of these two expressions? Try polylines with the assigned index color, and then change it to TrueColor and repeat both expressions.
(dumpallproperties (car (entsel)))
(getpropertyvalue (car (entsel)) "Color")
so please 4 listings. thx. also what Acad version do you use? English or not?
(vl-load-com)
(defun c:ExportToCsv ( / *error* f s i e d st sl tc)
    (if f (close f))
    (princ))
	    d (entget e))
	(setq tc (vla-get-truecolor (vlax-ename->vla-object e))
			     (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," (itoa (vlax-get tc x)))) '(red green blue))) 2))
		       sl)))))
  (if (and st sl
      (write-line l f)))
  (*error* "end"))
Message 18 of 24
hythamthelove
I tried them now and they work perfectly in all cases. Thank you so much for your efforts really appreciated
Message 19 of 24
ВeekeeCZ
Good, glad to help.
I'm still interested in those listings. Would you post them? thx.
Message 20 of 24
hythamthelove
That is a mix of both index colors and true colors.
Command: EXPORTTOCSV
54 found
"46,149,209",7.32
"210,45,188",14.63
"248,153,30",8.47
"247,122,43",16.93
"255,0,238",7.14
"44,170,147",14.28
"183,24,242",9.32
"0,255,255",18.63
"70,145,13",7.59
"181,245,20",15.17
"255,0,0",6.63
"135,46,220",13.25
"248,153,30",5.67
"0,255,255",11.33
"0,0,255",15.68
"241,222,14",12.15
"0,255,0",24.29
"184,148,235",11.11
"26,21,162",22.21
"248,153,30",11.84
"255,0,255",12.01
"0,255,0",6.80
"255,0,0",13.6
"255,255,0",9.25
"0,0,255",4.63
"44,170,147",20.60
"247,242,129",17.51
