GDA2020 conversion lisp
Kate.RobinsonR9FXS
Kate.RobinsonR9FXS
Hello, need a lisp that helps me block shift all my xrefs, because of the Australian grid shift GDA94 to GDA2020.
Basically need the lisp to unload all xrefs, unlock all layers, turn all frozen layers off then thaw the frozen layers so they're only turned off, select all objects in the xref and move by coordinate shift x(0.454),y(1.445)
TIA
Kate.RobinsonR9FXS
Believe i may have solved this myself but let me know if you see a better way.
I have tested and this does the job
(defun c:GDA94TO2020 ()
(command "-xref" "unload" "*" "")
(command "-layer" "unlock" "*" "")
(setq lay (cdr (assoc 2 (tblnext "layer" T))))
(while lay
(if (= (cdr (assoc 70 (tblsearch "layer" lay))) 1)
(progn
(command ".-layer" "off" lay "")
(setq lay (cdr (assoc 2 (tblnext "layer"))))
(command ".-layer" "thaw" "*" "")
(command "_.move" "_all" "" "0,0" "0.454,1.445")
(princ)
Moshe-A
@Kate.RobinsonR9FXS ,
what you did is OK works, well done 👍
better way? here is my shorter version.
As you can see, calling (tblnext) ones as test expression for (while) is enough [no need to use (tblserach) also]
the trick here is using variable tbl
(while (setq tbl (tblnext "layer" (not tbl)))
cause at first tbl is nil , (not tbl) returns T as the 2nd args for (tblnext) which rewind the layer table.
the next time tbl has a record and it's not nil so the loop spins until (tblnext) return nil (end of table records).
Moshe
(defun C:GDA94TO2020 (/ tbl lay)
 (command "._xref"  "_unload" "*" "")
 (command ".-layer" "_unlock" "*" "")
 ; turn all frozen layers to off
  (if (= (cdr (assoc 70 tbl)) 1)
   (command "._layer" "_off" (cdr (assoc 2 tbl)) "") ; turn layer off
  ); if
 ); while
 (command "._layer" "_thaw" "*" "")
 (command "._move"  "_all" "" "0,0" "0.454,1.445")
 (princ)
); C:GDA94TO2020
