Lisp Modification
Lisp Modification
inaamazmi
Lisp Modification
inaamazmi
I got a lisp that marks the intersection length as chainage. i want two modification.. the chainage text should be in "0+000.000" format the precision should be according to drawing
the lisp is here
vl-load-com)
(defun C:PipeAcrossStat ( / :GetInters ss en y d pt)
;----- Lee Mac ~ 19.01.10 www.theswamp.org
(defun :GetInters (ss / list->3D-point i j obj1 obj2 iLst)
(defun list->3D-point (lst)
(if lst (cons (list (car lst) (cadr lst) (caddr lst))
(list->3D-point (cdddr lst)))))
(setq i (sslength ss))
(while (not (minusp (setq j (1- i) i (1- i))))
(setq obj1 (vlax-ename->vla-object (ssname ss i)))
(while (not (minusp (setq j (1- j))))
(setq obj2 (vlax-ename->vla-object (ssname ss j))
iLst (append iLst (list->3D-point (vlax-invoke obj1 'IntersectWith obj2 acExtendNone))))))
iLst)
(if (and (princ "\nSelect ALL (poly)lines,")
(setq ss (ssget '((0 . "*LINE,ARC"))))
(not (initget 0))
(setq en (car (entsel "\nSelect a PIPELINE: ")))
(wcmatch (cdr (assoc 0 (entget en))) "*LINE")
(not (initget 0))
(setq y (cadr (getpoint "\nPick a dimension line: "))))
(foreach e (:GetInters ss)
(if (setq pt (list (car e) y 0.)
d (vlax-curve-getDistAtPoint en e))
(progn
(entmakex (list (cons 0 "LINE")
(cons 10 e)
(cons 11 pt)
(cons 8 "TEXT COVER")
(cons 62 210)
(cons 210 '(0. 0. 1.))
(entmakex (list (cons 0 "MTEXT")
(cons 100 "AcDbEntity")
(cons 100 "AcDbMText")
(cons 10 pt)
(cons 40 2)
(cons 50 (* 0.5 pi))
(cons 1 (strcat (rtos d 2 2) "m"))
(cons 71 4)
(cons 62 1)
(cons 63 2)
(cons 90 1)
(princ "\nWrong selection."))
(princ)
inaamazmi
sample drawing
Moshe-A
@inaamazmi ,
check this one
Moshe
(vl-load-com)
(defun C:PipeAcrossStat ( / zeroPrefix :GetInters ss en y d pt)
 (defun zeroPrefix (n l / k s)
  (if (<= (setq k (strlen (itoa n))) l)
   (progn
    (setq s (itoa n))
    (cond
     ((zerop (- l k))
      (itoa n)
     ); case
     ( t
      (repeat (- l k)
       (setq s (strcat "0" s))
     ); case
    ); cond
   ); progn
   "" ; return
  ); if
 ); zeroPrefix
  iLst
 ); :GetInters
          (not (initget 0))
          (not (initget 0))
    (progn
     (entmakex (list
		(cons 0 "LINE")
                (cons 10 e)
                (cons 11 pt)
                (cons 62 210)
    (entmakex (list
	       (cons 0 "MTEXT")
               (cons 10 pt)
               (cons 40 2)
              ; (cons 1 (strcat (rtos d 2 2) "m"))
               (cons 1 (strcat "0+" (zeroPrefix d 3) "." (zeroPrefix 0 3) "m"))
               (cons 71 4)
               (cons 62 1)
               (cons 63 2)
               (cons 90 1)
    ); progn
   ); if
  ); foreach
 ); if
 (princ)
inaamazmi
@Moshe-A  showing eror
Moshe-A
@inaamazmi ,
As your request my part was format the text "+0.000.000"
i did not have success on running this lisp cause i do not know how?!
Moshe
pbejse
(defun C:PipeAcrossStat	(/ :GetInters ss en y d pt)
(defun _format ( n / nr ns i h)
  (setq head
	(cond
	  ((setq h (nth (1- (setq i (strlen (setq nr (itoa (fix n))))))
		     	'("00" "0" "")))(strcat "0+" h (rtos n 2 )))
	  ((strcat (substr nr 1 (- i 3)) "+"
		   (substr (rtos n 2 ) (- i 3)))
      (if lst
			      i	(1- i)
	      iLst (append
		     iLst
		     (list->3D-point
    iLst
	   (not (initget 0))
	   (not (initget 0))
	(progn
			  (cons 10 e)
			  (cons 11 pt)
			  (cons 62 210)
			  (cons 10 pt)
			  (cons 40 2)
			  (cons 1 (strcat (_format d) "m"))
			  (cons 71 4)
			  (cons 62 1)
			  (cons 63 2)
			  (cons 90 1)
  (princ)
HTH
inaamazmi
Thanks for your help it working @pbejse
