How to rotate dimangular text
devitg
Advisor Advisor
devitg
Hi , please help me . I need to rotate, by lisp,   angular dimension as follow find attached a sample dwg
Moshe-A
@devitg  hi,
check this, i not fully sure but it look like the mtext rotation is not part of the dimension style.
works?
Moshe
; dimenstion text rotate
(defun c:dimtxtrot (/ collectPoints ; local function
		      ss ename AcDbDim pts int)
 (defun collectPoints ()
   (mapcar
     (function
       (lambda (prop)
         (vlax-safearray->list (vlax-variant-value (vlax-get-property AcDbDim prop)))
     '(textPosition ExtLine1StartPoint ExtLine1EndPoint ExtLine2StartPoint ExtLine2EndPoint)
 ); collectPoints
 (if (setq ss (ssget '((0 . "dimension") (100 . "AcDbAngularDimension"))))
  (progn
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq AcDbDim (vlax-ename->vla-object ename))
    (setq pts (collectPoints))
    (if (setq int (inters (cadr pts) (caddr pts) (cadddr pts) (last pts)))
     (vla-put-textRotation AcDbDim (angle int (car pts)))
    (vlax-release-object AcDbDim)
   ); foreach
  ); progn
 ); if
 (princ)
); c:dimtxtrot
