Hi guys,
I'm looking for a way to adapt the GATTE2 code to accept dynamic blocks.
I did a search and found several posts about it, but all unsolved.
http://www.theswamp.org/index.php?topic=37602.msg426157#msg426157
http://www.cadtutor.net/forum/showthread.php?93037-gatte-for-use-on-dynamic-blocks
http://www.cadtutor.net/forum/showthread.php?44232-Gatte-for-Db-S
and the closest solution (in my opinion)
I can not give up. So I'll ask... Someone could please change the GATTE2 code to also work with dynamic blocks?
I found the code here: http://www.cadtutor.net/forum/showthread.php?50268-GATTE2-%28Global-Attribute-Edit-with-Layout-Selec...
;| ;; GATTE2: By Steve K (Date 10/2009) ;; v1.0 Initial Release ;; v1.01 Minor amendments (nothing externally noticable) ;; v1.02 Localised variables & Working again.. ;; ;; Description: A drawback of the standard GATTE command is that the user ;; can not chose which layouts to replace text on (it will ;; overwrite the text on every layout). ;; GATTE2 gives the user the option to select which layouts ;; to apply the attribute change to. ;; |; ;; (defun c:gatte2(/ *error* en obj doc tag atts attstr txtstr tablst laystr count blkObj blkName sel) (vl-load-com) ; Error Handler (Lee Mac's) ; (defun *error* (err) (if doc (vla-EndUndoMark doc)) (if (not (wcmatch (strcase err) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " err " **"))) (princ)) ; Get Layout Name Function ; ; @param An object. ; ; @return Layout Name object is on. ; (defun getlayout (Obj) (vla-get-Name (vla-get-layout (vla-objectidtoobject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-ownerid Obj))))) ; Main Process ; (Cond ((not (setq en (nentsel))) (princ "\nNothing Selected.")) ((and (not (= (length en) 4)) (not (eq (cdr (assoc 0 (entget (setq en (car en))))) "ATTRIB"))) (princ "\nEntity not an Attribute or Block.")) ((if (listp en) (progn (setq blkObj (vlax-ename->vla-object (car (nth 3 en)))) (if (setq atts (vlax-invoke blkObj 'getAttributes)) (progn (foreach att atts (if attstr (setq attstr (strcat attstr " " (vla-get-tagstring att))) (setq attstr (vla-get-tagstring att)))) (while (not (member (setq tag (strcase (getstring (strcat "\nKnown tag names for block: " attstr "\nEnter an attribute name: ")))) (mapcar 'vla-get-tagstring atts))) (princ "Entry not an Attribute.") ) (setq obj (nth (vl-position tag (mapcar 'vla-get-tagstring atts)) atts)) nil ) T ) ) (not (setq obj (vlax-ename->vla-object en))) ) (princ "\nNo Tags Exist.") ) ((not (setq tablst (GetTabList))) (princ "\nNo Tabs Selected.")) ( T; Else Proceed (setq count 0 doc (vla-get-activedocument (vlax-get-acad-object)) blkName (vla-get-name (vla-ObjectIdtoObject doc (vla-get-OwnerId Obj)))) (princ (strcat "\nBlock Name: " blkName " \tAttribute tag: " (vla-get-tagstring obj))) (vla-StartUndoMark doc) (setq txtstr (getstring T "\nEnter new Text String: ")) (setq laystr (car tablst)) (foreach lay (cdr tablst) (setq laystr (strcat laystr (chr 44) lay)) ) (if (ssget "_X" (list (cons 0 "insert") (cons 2 blkName) (cons 410 laystr) (cons 67 1))) (progn (princ (strcat "\nThe following attributes were changed to \"" txtstr "\"..")) (vlax-for bl (setq sel (vla-get-activeselectionset doc)) (foreach att (vlax-invoke bl 'getAttributes) (if (eq (vla-get-tagstring att) (vla-get-tagstring obj)) (progn (setq count (1+ count)) (princ (strcat "\nLayout: " (getlayout bl) "\tOld Text: " (if (eq (vla-get-textstring att) "") "*empty*" (vla-get-textstring att)))) (vla-put-textstring att txtstr)) ) ) ) (vla-delete sel) (princ (strcat "\nModified " (itoa count) " attributes total.\n")) (vla-EndUndoMark doc) )(princ "\nNo Blocks Found.")) )) (princ) ) ;; ;| End: GATTE2 ;; |; ;; CAB's Get Layouts Program ;; ;; (defun GetTabList (/ dclfile dcl# layouts ptr tablist) (setq dclfile "LayoutSelect.dcl") (cond ((< (setq dcl# (load_dialog dclfile)) 0) ; Error (prompt (strcat "\nCannot load " dclfile ".")) ) ((not (new_dialog "layoutselect" dcl#)) ; Error (prompt (strcat "\nProblem with " dclfile ".")) ) (t ; No DCL problems: fire it up (setq layouts (orderedLayoutList)) (start_list "layouts") (foreach one layouts (add_list one) ) (end_list) (action_tile "layouts" "(setq ptr $value)") (action_tile "ok" "(done_dialog 5)") (action_tile "cancel" "(done_dialog 1)") (setq action (start_dialog)) (unload_dialog dcl#) (if (and ptr (= action 5)) ; get the list of selections to list of numbers (setq ptr (read (strcat "(" ptr ")")) tablist (mapcar '(lambda (x) (nth x layouts)) ptr)) ) ) ; end cond T ) ; end cond tablist ) ;; ;; ;; ;; OrderedLayoutList: Similar to (layoutlist) except returns list that is ;; ;; ordered by current tab order (not alphabetically) ;; ;; (defun orderedLayoutList (/ laylst) (vl-load-com) (vlax-for lay (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (setq laylst (cons lay laylst)) ) (cdr (mapcar 'vla-get-name (vl-sort laylst (function (lambda (a b) (< (vla-get-taborder a)(vla-get-taborder b)) ))))) ) ;; ;; ;;
LayoutSelect.DCL
layoutselect : dialog { label = " Layout Selector by CAB v1.0"; : boxed_row { label = "< Tabs >"; :list_box { key = "layouts"; height = 15 ; width = 30 ; fixed_width = true; multiple_select = true; alignment = centered ; } } : row { : button { key = "ok" ; label = "OK" ; fixed_width = true ;} : cancel_button {} } }
Many thanks!
Marcelo
