Entmake Text Problem
I'm trying to use entmake to instert a simple bit of text at a certain point.
The text needs to be justified Middle Centre.
I'm having trouble getting the 72 & 73 codes correct.
The code works with the lines below semi coloned off but the text is justified left.
Without the semi colons the text gets inserted at 0,0 instead of the point 'ins'
        (entmake
            (list
               '(000 . "TEXT")
               '(100 . "AcDbEntity")
               '(100 . "AcDbMText")
    		(cons 10 ins)         		;; Insertion point
               '(001 . "My Text Here")		;; Contents
               	(cons 040 hght)			;; Text Height
             	(cons 050 txtrot)		;; Rotation
;             	(cons 072 4)
;	        (cons 073 4)
Has any kind person got any ideas?
ВeekeeCZ
See this for correct codes. Also you need to add code 11, same as 10... a difference is calculated automatically.
(entmake (list
	    '(000 . "TEXT")
	    (cons 11 ins)         		;; Alignment point
	    (cons 072 1)
	    (cons 073 2)
This might be helpful as well.
Bang on, thank you very much BeekeeCZ
