WHY? ; error: bad argument type: lselsetp
nychoe1
nychoe1
;;; textbox
(defun c:txt (/ e_list ap1 ap2 ax ay dx dy agng tp1 op1 op2 op3 op4)
   (setq ss (entsel  "\n\tselect text : "))
      (setq en (ssname ss 0))
      (setq e_list (entget en))
      (setq ap1 (car (textbox e_list)))
      (setq ap2 (cadr (textbox e_list)))
      (setq ax (car ap2) ay (cadr ap2) )
      (setq dy (/ ay 4) dx (/ ay 2))
      (setq agng (cdr (assoc 50 e_list)))
      (setq tp1 (cdr (assoc 10 e_list)))
      (setq op1 (polar tp1 (- agng pi) dx))
      (setq op1 (polar op1 (- agng (/ pi 2)) dy))
      (setq op2 (polar op1 agng (+ ax (* dx 2))))
      (setq op3 (polar op2 (+ agng (/ pi 2)) (+ ay (* dy 2))))
      (setq op4 (polar op3 (+ agng pi) (+ ax (* dx 2))))
      (command "pline" op1 op2 op3 op4 "c")
   (princ)
ВeekeeCZ
Beacause entsel retuns a list of (entname picked-point). Entname you get using (car (entsel)). But if you dont need a point, ssget is better. It allows you pre-selection. Also it's easier to set some filter for entities you need. Read about ssget.
Spoiler
   (setq esel (entsel  "\n\tselect text : "))
      (setq en (car esel))
   (princ)
(defun c:txt2 (/ e_list ap1 ap2 ax ay dx dy agng tp1 op1 op2 op3 op4)
  (princ "\nNeed TEXT,")
  (if (setq ss (ssget "_+.:E:S" '((0 . "TEXT"))))
    (progn
      (setq e_list (entget (ssname ss 0))
            ax (car ap2)
            ay (cadr ap2)
            dy (/ ay 4)
            dx (/ ay 2)
      (command "_.pline" op1 op2 op3 op4 "_c"))
    (princ "\nWrong selection, required TEXT."))
  (princ)
Did you tried this?
Maybe easier would be calculation of just two points and draw rectangle with angle.
nychoe1
I got it. thank you for big help.
