force a Tab keystroke in dialog box
zale-86
zale-86
I'm using Blubeam Cad Revu and am trying to create a routine to run existing batch files. The trouble is that the Bluebeam command will not run silently so I want to move though the dialog box programmatically. Is there a way to force a Tab keystroke within a lisp command? \t does not seem to work.
I was trying this.... (command "bsibatch " \t "" \t " "01.bbx" "")
Thanks in advance
paullimapa
Unforutnatley, if the Blue Beam program does not provide for a command line option, then Lisp cannot send a tab key code to maneuver around the dialog window.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
