float to string
float to string
float to string
Hi guys,
i am looking for a AutoLISP command which converts a float to a string.
Pls help!
ВeekeeCZ
A float is a real. So (rtos) function.
> (setq fl (float 2))
> (rtos fl 2 2)
2.00
>(rtos fl 2 0)
2
Watch DIMZIN sysvar for tailing zeros.
See HERE about the conversion functions.
rtos works
Can set the precision if required
eg. (rtos pi 2 2 ) returns "3.14"
(rtos pi 2 3 ) returns "3.142"
pbejse
Pls help!
Hmmmmmn
This?
(defun _floattostring  (f)
      (defun replace-n  (new n lst /)
            (mapcar '(lambda (a)
                           (if (= (setq n (1- n)) -1)
                                 new
                                 a))
                    lst))
(if (eq (Strcase f t)  "float")
    (progn
      (setq n -1
            f (vl-string->list f))
      (setq strin
                 (mapcar
                       (function
                             (lambda (a b c)
                                   (setq d    nil
                                         n    (1+ n)
                                         symb (if (minusp a)
                                                    1-
                                                    1+))
                                   (repeat (abs a)
                                         (setq d (cons
                                                       (setq f    (replace-n
        (setq b (symb b))
        n
        f))
                                                       d)))
                       '(13 8 3 8 -6)
                       f
                       '(115 116 114 105 110))
      (textscr)
      (foreach
             itm
             (cons '(102 108 111 97 116)
                   (append (apply 'append (mapcar 'reverse strin))
                           '((115 116 114 105 110 103))))
            (print (vl-list->string itm))
            (princ)
      (princ "<<--- TADA!! ")
    (alert(Strcat "\nHey!! I said float not " (Strcase f )))
    (princ)
(_floattostring "float")
HTH
"All work and no play makes pBe a dumb boy"
