Create layer properties filter
Sandervp
Message 1 of 26
Sandervp
Hello everybody,
I have a lisp which creates several layer group filters. But I want to add some property filters also.
My lisp file is containting rules like this: (Command "-layer" "filter" "n" "g" "*example*" "" "*exampl*" "example" "")
I want to add (Command "-layer" "filter" "n" "p".......... but how further?
I want to have property filters for "off", "on", "frozen" and "thawed"
Could somebody help me?
Sander
Replies (25)
Message 2 of 26
ВeekeeCZ
... All
OFF=="False"
FROZEN=="False"
or both
OFF=="False" AND FROZEN=="False"
Message 3 of 26
Sandervp
Hello BeekeeCZ
thanks for your reply but I do not understand it really..
After I create the property filter for all the layers which are off, I see all the layers also the which are on or frozen.
What am I doing wrong?
Message 4 of 26
ВeekeeCZ
Maybe my command line list clear this out.
Spoiler
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: filter
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]: new
Select layer filter type [Group/Property]: p
Enter parent layer filter <All>: all
Enter parent layer filter <All>: All
Enter property filter definition: OFF=="False"
Enter name for layer filter: LayON
Current layer filter: "LayON"
Enter property filter definition: FROZEN=="True"
Enter name for layer filter: LayFRZ
Current layer filter: "LayFRZ"
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]: x
Command:
Btw You can see that there are multiple "Enter parent layer filter <All>: all" lines. I had to set "All" three times until it was accepted (acad 2016). Test this behaviour! This may be a problem for your lisp. Perhaps use just "" for enter intead of "a" or "all".
Message 5 of 26
Sandervp
Thank you BeekeeCZ,
If I do this like you, om the command line, it works. But if I put this:
(Command "-layer" "filter" "n" "p" "" "frozen=="true"" "" "frozen" "")
 into a lisp it doesn't work..
If I look in the text window I see this:
Command: -layer
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: filter
Current layer filter: "example"
Enter property filter definition: frozen==
Command:
It doesn't take frozen=="true".
greetings
Message 6 of 26
ВeekeeCZ
Quotes are the problem. You need to use the backslash character \ with quote marks.  ... See the other special characters...... HERE
(Command "-layer" "filter" "n" "p" "" "frozen==\"true\"" "" "frozen" "")
Message 7 of 26
Sandervp
Thanks!!
I'd made the filter "ON".
(Command "-layer" "filter" "n" "p" "" "off==\"false\"" "" "on" "")
But I'm seeing the frozen layers also.
In your reply you wrote:
or both
How do I put this into the command string?
Is it also possible to group all the filters (Like in windows explorer) by using a command string in my lisp? You have got one map with all the group filters and one map with all the property filters?
Message 8 of 26
ВeekeeCZ
Same pattern as before... all inner quotes with the backslash.
"OFF==\"False\" AND FROZEN==\"False\""
How about try it? 🙂
If you want to create sub-filter, use some filter you aready have for "patern layer filter" instead of "All".
I think you can combine filters by same rules as you can in dialog box.
Spoiler
Command: -LAYER
Current layer:  "0"
Enter name for layer filter: OFF
Current layer filter: "OFF"
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]: N
Select layer filter type [Group/Property]: P
Enter parent layer filter <All>: OFF
Enter property filter definition: FROZEN=="False"
Enter name for layer filter: FROZEN
Current layer filter: "FROZEN"
Select layer filter type [Group/Property]: g
Enter name list of layer(s) to include: 0
Enter name for layer filter: zero
Current layer filter: "zero"
Message 9 of 26
Sandervp
Thanks again BeekeeCZ!!
All the layer filters are correct and ordered in 2 group filters/ maps!
Message 10 of 26
Sandervp
Sorry to interrupt you again BeekeeCZ....
I've changed my lisp file. The lisp file must create a parent filter first (called "No_Xref_Layers") and after this filter is created, it has to create more filters.
If I use the command "Xrefnot" or "createfilters" one by one, it's no problem.
But if I combine these commands in the lisp file, by creating another command, it doesn't work. They are "unknown commands" after using the lisp.
Something is wrong, but I can't figure it out..
This is the combined lisp file:
(defun c:XREFNOT ( / xdict dict xrecname )
 (vl-load-com)
    (setq xdict
        (vlax-vla-object->ename
            (vla-getextensiondictionary
                (vla-get-layers
                    (vla-get-activedocument (vlax-get-acad-object))
    (setq dict
        (if (setq dict (dictsearch xdict "ACAD_LAYERFILTERS"))
            (cdr (assoc -1 dict))
            (dictadd xdict "ACAD_LAYERFILTERS"
                (entmakex
                        (0 . "dictionary")
                        (100 . "AcDbDictionary")
                        (280 . 0)
                        (281 . 1)
    (princ
        (if (dictsearch dict (setq xrecname "No_Xref_Layers"))
            (strcat
                "Layer filter named <"
                xrecname
                "> already exists."
            (if
                (dictadd dict xrecname
                    (entmakex
                        (append
                                (0 . "xrecord")
                                (100 . "AcDbXrecord")
                                (280 . 1)
                            (list (cons 1 xrecname))
                                (1 . "~*|*")
                                (1 . "*")
                                (1 . "*")
                                (70 . 0)
                                (1 . "*")
                                (1 . "*")
                                (-3
                                    (   "ACAD"
                                        (1000 . "( NAME== \"~*|*\" )")
                (strcat
                    "Created layer filter named <"
                    xrecname
(command ".-layer" "filter" "set" "No_Xref_Layers" "")
    (princ)
);_End of defun
(Defun C:createfilters ()
     (Command "-layer" "filter" "n" "g" "No_Xref_Layers" "**" "Lagen" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*57*" "" "57 - LUCHT" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*56*" "" "56 - CV" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*55*" "" "55 - GKW" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*54*" "" "54 - GASSEN" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*53*" "" "53 - WATER" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*52*" "" "52 - RIOOL" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*5*" "" "5 - W-INSTALLATIE" "")
     (Command "-layer" "filter" "n" "g" "Lagen" "*WM*" "" "5X - MAATVOERING" "")
     (Command "-layer" "filter" "n" "p" "No_Xref_Layers" "Eigenschappen" "Eigenschappen" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "frozen==\"true\"" "" "frozen" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "off==\"true\"" "" "off" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "off==\"false\" and frozen==\"false\"" "" "on" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "frozen==\"false\"" "" "thawed" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "locked==\"true\"" "" "locked" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "locked==\"false\"" "" "unlocked" "")
     (Command "-layer" "filter" "n" "p" "Eigenschappen" "plottable==\"false\"" "" "no plot" "")
(princ)
);_End of defun
(Defun C:ftr ()
     (Command "qsave")
     (Command "xrefnot")
     (Command "createfilters")
(princ "\n...All layer filters have been created.")
(princ)
Message 11 of 26
ВeekeeCZ
You cannot call your functions with (command). You need to use their names - including "c:" if there is one.
(Defun C:ftr ()
     (Command "qsave")
     (c:xrefnot)
     (c:createfilters)
(princ)
Message 12 of 26
Sandervp
It's working perfect! It makes it a lot easier for me because the many layers in our drawings!
Message 13 of 26
SKUIBREAKER2
THIS IS SPECTACULAR!!     Thank you this is so very helpful!
 (vl-load-com)
    (setq xdict
                (vla-get-layers
    (setq dict
                (entmakex
                        (0 . "dictionary")
                        (280 . 0)
                        (281 . 1)
    (princ
            (strcat
                xrecname
                "> already exists."
            (if
                    (entmakex
                        (append
                                (0 . "xrecord")
                                (280 . 1)
                                (1 . "~*|*")
                                (1 . "*")
                                (1 . "*")
                                (70 . 0)
                                (1 . "*")
                                (1 . "*")
                                (-3
                                    (   "ACAD"
                (strcat
                    xrecname
    (princ)
);_End of defun
     (Command "-layer" "filter" "n" "g" "No_Xref_Layers" "**" "GROUPS" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "A-*" "" "A-ARCH" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "P-*" "" "P-PLUMBING" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "S-*" "" "S-STRUCT" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "M-*" "" "M-HVAC" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "E-*" "" "E-ELECTRICAL" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "*GRID*" "" "GRID" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "*COLS*" "" "COLS" "")
     (Command "-layer" "filter" "n" "g" "GROUPS" "*DOOR*" "" "DOORS" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*GLAZ*" "" "WINDOWS" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*HRAL*" "" "RAILING" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*PAT*" "" "PATTERNS" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*FURN*" "" "FURNITURE" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*A-ANNO*" "" "ANNOTATIONS" "")
	(Command "-layer" "filter" "n" "g" "GROUPS" "*DIM*" "" "DIMENSIONS" "")
     (Command "-layer" "filter" "n" "p" "No_Xref_Layers" "PROP" "PROP" "")
     (Command "-layer" "filter" "n" "p" "PROP" "frozen==\"true\"" "" "frozen" "")
     (Command "-layer" "filter" "n" "p" "PROP" "off==\"true\"" "" "off" "")
     (Command "-layer" "filter" "n" "p" "PROP" "off==\"false\" and frozen==\"false\"" "" "on" "")
     (Command "-layer" "filter" "n" "p" "PROP" "frozen==\"false\"" "" "thawed" "")
     (Command "-layer" "filter" "n" "p" "PROP" "locked==\"true\"" "" "locked" "")
     (Command "-layer" "filter" "n" "p" "PROP" "locked==\"false\"" "" "unlocked" "")
     (Command "-layer" "filter" "n" "p" "PROP" "plottable==\"false\"" "" "no plot" "")
(princ)
);_End of defun
(Defun C:ftr ()
     (Command "qsave")
     (c:xrefnot)
     (c:createfilters)
(princ)
Message 14 of 26
SKUIBREAKER2
i JUST TACKED THIS ONTO TOO
(Command "-layer" "filter" "n" "p" "PROP" "NAME==\"A-*\"" "A-ARCHITECTURAL" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"P-*\"" "P-PLUMBING" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"S-*\"" "S-STRUCTURAL" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"M-*\"" "M-HVAC" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"E-*\"" "E-ELECTRICAL" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*GRID*\"" "GRIDS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*COLS*\"" "COLUMNS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*DOOR*\"" "DOORS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*GLAZ*\"" "WINDOWS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*HRAL*\"" "RAILING" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*PAT*\"" "PATTERNS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*FURN*\"" "FURNITURE" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*A-ANNO*\"" "ANNOTATIONS" "")
(Command "-layer" "filter" "n" "P" "PROP" "NAME==\"*DIM*\"" "DIMENSIONS" "")
 Obviously, I had to change the Group name so they didn't match the new Property names
Message 15 of 26
SKUIBREAKER2
STEP 2:    IS TO MODIFY the LISP TO AUTOMATICALLY CHANGE ALL OF the layers in each group or property filter into a specific color.
This will allow super fast changing of Arch & Structural files into backgrounds that print faded or transparent.
Message 16 of 26
Sandervp
Hello @ВeekeeCZ,
I've added some extra filters to my lisp. These filters appear between the other layer filters but they doesn't contain any layer which meet the requirements.
If I look at the main filter ("No_Xref_Layers"), the layers are visible. But if I look at the new (sub) filters, no layer appears. The new filters doesn't contain any layer at all..
What's wrong with my lisp?
I've copied "(Command "-layer" "filter" "n" "p" "Lagen" "name==\"*57*\"" "57 - LUCHT" "")" twice and I've changed this into  "(Command "-layer" "filter" "n" "p" "Lagen" "name==\"*WT*\"" "5X - TEKST" "")" and "(Command "-layer" "filter" "n" "p" "Lagen" "name==\"*$1*\"" "OVERIGE" "")".
Could you help me?
I've attached the new lisp to this reply.
Greets Sander
Message 17 of 26
ВeekeeCZ
Hi. Man, I tend to answer NO DWG, NO HELP. Actually I would not answer at all for that reason. Fortunately for you I've remembered that you've posted dwg before so I've made the effort and found it in the another thread.
Your code worked/s for me in C3D 2016 despite the fact, that the layer filter properties dialog does not understand filter definitions written low case and also you have too many "" in all property filters (frozen, locked, etc...).
(defun c:FTR nil
  (command  "_.QSAVE")
  (command "_.-LAYER" "_Filter" "_N" "_P" "All" 		"NAME== \"~*|*\"" 				"No_Xref_Layers" ) 		(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "No_Xref_Layers" "NAME==\"*\"" 					"Lagen" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*57*\"" 				"57 - LUCHT" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*56*\"" 				"56 - CV" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*55*\"" 				"55 - GKW" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*54*\"" 				"54 - GASSEN" ) 		(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*53*\"" 				"53 - WATER" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*52*\"" 				"52 - RIOOL" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*5*\"" 				"5 - W-INSTALLATIE" ) 		(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*WM*\"" 				"5X - MAATVOERING" ) 		(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*WT*\"" 				"5X - TEKST" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Lagen" 		"NAME==\"*$1*\"" 				"OVERIGE" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "No_Xref_Layers" 	"Eigenschappen" 				"Eigenschappen" ) 		(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"FROZEN==\"TRUE\"" 				"_Frozen" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"OFF==\"TRUE\""					"off" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"OFF==\"FALSE\" AND FROZEN==\"FALSE\""		"on" ) 				(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"FROZEN==\"FALSE\"" 				"thawed" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"LOCKED==\"TRUE\"" 				"locked" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"LOCKED==\"FALSE\"" 				"unlocked" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschappen" 	"PLOTTABLE==\"FALSE\"" 				"no plot" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "All" 		"Eigenschap" 					"Eigenschap" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"FROZEN==\"TRUE\"" 				"_Frozen_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"OFF==\"TRUE\"" 				"off_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"OFF==\"_FALSE\" AND FROZEN==\"FALSE\"" 	"on_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"FROZEN==\"FALSE\"" 				"thawed_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"LOCKED==\"TRUE\"" 				"locked_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"LOCKED==\"FALSE\"" 				"unlocked_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "_N" "_P" "Eigenschap" 		"PLOTTABLE==\"FALSE\"" 				"no plot_" ) 			(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (command "_.-LAYER" "_Filter" "s" 	"No_Xref_Layers") 											(if (> (getvar 'CMDACTIVE) 0) (command ""))
  (princ)
Good luck.
Message 18 of 26
SKUIBREAKER2
I will try to look at it when I get time.
Message 19 of 26
SKUIBREAKER2
Oh crap,,, nevermind ,,, sorry just realized that message wasn't directed towards me.  Wish I could edit my dang post.
Message 20 of 26
cwtwong
hi, how to change the layer color after the filter by script?
Thanks.
