fixed-length text
fixed-length text
Message 1 of 12
fixed-length text
Hello
What is the best way to deal with this situation?
I have an external text file.
"BK;1/1000;JRN10069;GG1;-3.223504;-40.696405" ;external file text
I would like to leave you this way
"BK      1/1000       JRN10069     GG -3.223504    -40.696405    "  objective
The text 1 to the first (;) can only have a maximum length of 7 characters. If the text is more than 7, return only the first 7. If less than 7, complete with spaces.
The text 2 Second (;) can only have a maximum length of 12 characters. If the text is more than 12 return only the first 12. If it is less than 12 complete with spaces.
The text 4 fourth (;) can only have a maximum length of 2 characters. If the text has more than 2 return only the first 2. If it has less than 2 complete with spaces.
Okay, I can transform the string into a list and manipulate them independently, but how to deal with fixed length? not letting an item be different from what is allowed?
Replies (11)
Message 2 of 12
chriscowgill7373
 I think you would want this:
(substr string start [length] )
Returns a substring of a string
https://knowledge.autodesk.com/fr/search-result/caas/CloudHelp/cloudhelp/2015/FRA/AutoCAD-AutoLISP/f...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 12
I know these functions, but that's not what I need.
Message 4 of 12
chriscowgill7373
I guess I dont understand what you are wanting.  You separate the items so you can look at them individually, then feed their string through the function, and spit back out the desired output into cad that meets the requirements.  If you are looking to do something with an existing external file that you want to create a new one, you can write back out to the text file.
Message 5 of 12
pbejse
Post another another sample @Anonymous , one that is over the maximum number of characters and show us the results.
Also, post your string to list function here, we will incorporate that on the final code.
Message 6 of 12
I'm trying to create a function that writes to a list_box
it is like this:
objective:
example text file
DT;17/1000;JRN10069;TR;-3.223504;-40.696405
DT;21/2000;JRN10069;TR;-3.222978;-40.696062
CC;21/2000;JRN10069;TR;-3.223516;-40.695864
here is the function:
(defun :Redlist_box ( )
  (setq name (getfiled "Select *.csv"  (getvar 'dwgprefix) "txt;csv" 16))
  (setq dados (open name "r"))
  (setq lst '(""))
  (while (setq line (read-line dados))
    (setq lst (append lst (list line)))
(:Redlist_box)
;$!lst  (real)
;$ ("" "DT;17/1000;JRN10069;TR;-3.223504;-40.696405" "DT;21/2000;JRN10069;TR;-3.222978;-40.696062" "CC;21/2000;JRN10069;TR;-3.223516;-40.695864")
;objective
;$ ("" "DT               17/1000        JRN10069        TR                   -3.223504            -40.696405" "DT               21/2000        JRN10069        TR                   -3.222978            -40.696062" "CC               21/2000        JRN10069        TR                   -3.223516            -40.695864")
Each item has a maximum length and cannot be exceeded, if smaller, complete with spaces
Message 7 of 12
pbejse
example text file
What were going to do is skip the string to list bit and process the string as it is.
You should be able to put this together @Anonymous
(defun _padSpace ( s l)
	(if (< (strlen s) l) (_padSpace (strcat s " ") l) s)
(defun _Breakdown (Str)
(strcat (apply 'strcat
  (mapcar '(lambda (n / p part)
	     (setq p (vl-string-position 59 str))
	     (setq part
	     	(cond
		       	(( < p n) (_padSpace (substr str 1 p) n))
			(( >= p n) (strcat (substr str 1 (1- n)) " "))
	     (setq str (substr str (+ 2 p)))
	     part)
	'(8 13 13 3 13))
    str
Sample run
(foreach itm
	 '("DT;17/1000;JRN10069;TR;-3.223504;-40.696405"
	   "PBEJSEFORCETHIS;Frjuniornogueira;JRN10069;Autodesk;-3.223504;-40.696405"
  (print (_breakdown itm))(princ)
"BK      1/1000       JRN10069     GG -3.223504    -40.696405"
"PBEJSEF Frjuniornogu JRN10069     Au -3.223504    -40.696405"
HTH
EDIT: Not sure about the last "part" < -40.696405 > . i will leave you to deal with that.
This includes the last part with spaces "   " , play around with the value until it suites you.
(apply 'strcat
	     (setq part
	     	(cond
	     (setq str (if p (substr str (+ 2 p)) str ))
	     part)
	'(8 13 13 3 13 13))
Message 8 of 12
Wow!! You are impressive!! @pbejse
Thank you!!
Message 9 of 12
hak_vz
You will get it
(defun string_to_list ( str del / pos )
        (if (setq pos (vl-string-search del str))
            (cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
            (list str)
(defun trim_to_length (str len) (strcat (substr str 1 len) (substr "                   " 1 (- len (strlen str)))))
(setq category_lengths '(7 12 15 18))
(setq str (string_to_list  str ";"))
(mapcar '(lambda (x y) (trim_to_length x y)) str category_lengths)
My post is a few minutes late but maybe you can find it useful.
Miljenko Hatlak
Message 10 of 12
pbejse
Thank you!!
You are welcome Frjuniornogueira I'm sure you'll eventually come up with the solution on your own.
Glad it helps.
Cheers
Message 11 of 12
@hak_vz This also works very well, thanks !!
Message 12 of 12
pbejse
I like the approach, nice idea  👍
