Trim to polyline midpoint when selecting unwanted polyline half
Hello. Is there a command that trims to a polyline midpoint when selecting an unwanted polyline half?
Thank you.
  • Trim
Kent1Cooper
@Anonymous wrote:
.... Is there a command that trims to a polyline midpoint when selecting an unwanted polyline half? ....
If you can be counted on to select it in an unambiguous location [where nothing else might be "seen" instead], something like this [minimally tested]:
(defun C:PLCHO ; = PolyLine Cut Half Off
  (/ plsel)
  (setq plsel (entsel "\nSelect Polyline within half-length to be cut off: "))
  (command "_.lengthen" "_total"
    (/ (vlax-curve-getDistAtParam (car plsel) (vlax-curve-getEndParam (car plsel))) 2)
    (cadr plsel) ""
  ); command
  (princ)
); defun
Kent Cooper, AIA
That's it! Thanks, Kent.
Sea-Haven
As length is a property can also do this way.
Thanks Kent learn something new all the time "Lengthen"
    (/ (vlax-get (vlax-ename->vla-object (car plsel)) 'Length) 2)
    (cadr plsel) ""
  ); command
ВeekeeCZ
Yes, one of my favorites commands. The command also has the "percent" option...
(defun c:PLCHO ()
  (command "_.lengthen" "_percent" 50)
  (princ)
Sea-Haven
Nice % and pick a side to remove.
lena.talkhina
Hello @Anonymous !
Great to see you here on LISP forum.
And you already received a solution! This is awesome!
Don't hesitate to ask any question you have by creating a new thread.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
