First time lisper failing with "too many arguments"
Good day!
I'm having an issue trying to modify a lisp routine that works for a single object to make it run for a selection of objects. It's very simple. I'm trying to copy multiple dimension values to a clipboard with a "; " string in between each of the dimensions.
The original script that works for copying a single dimension value to a clipboard:
(Defun c:Dim2Clip  (/ ss st 2ClipB)
  (vl-load-com)
 (print "Select Dimension...")
         (if (setq ss (ssget "_+.:S" '((0 . "*DIMENSION"))))
           (progn (setq st (vla-get-measurement (setq vl (vlax-ename->vla-object (ssname ss 0)))))
                  (vlax-invoke
                                 (vlax-get (vlax-get (setq 2ClipB (vlax-create-object "htmlfile")) 'ParentWindow)
                                           'ClipBoardData)
                                 'SetData
                                 "Text"
                                 (rtos st))
                  (vlax-release-object 2ClipB)))
This is my modification that doesn't work with a "too many arguments" error.
(Defun c:ddupa  (/ pat ss i st 2ClipB)
  (vl-load-com)
  (setq pat "")
         (if (setq ss (ssget "_+.:E:S" '((0 . "*DIMENSION"))))
		 (repeat (setq i (sslength ss))
           (progn (setq st (vla-get-measurement (setq vl (vlax-ename->vla-object (ssname ss 0))))))
		   (setq pat (strcat pat (strcat (rtos st) "; ")))
		   (list (ssname ss (setq i (1- i))) '(0 0 0))
		   );repeat
                  (vlax-invoke
                                           'ClipBoardData)
                                 'SetData
                                 "Text"
                                 pat)
I would be very grateful for any assistance with this. I'm in a rush with some work that would be singificantly more efficient with this working.
pbejse
  (vl-load-com)
  (setq pat "")
  (if (setq ss (ssget '((0 . "*DIMENSION"))))
    (progn
		   (setq vl
			  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
      )					;repeat
      (vlax-invoke
			    'ParentWindow
		  'ClipBoardData
	'SetData
	"Text"
	pat
pbejse
on your code
(if
(setq ss (ssget  '((0 . "*DIMENSION")))) <-- none single object selection mode
	(progn  <--- move one line up
	  (repeat (sslength ss)
	    (ssdel (ssname ss 0)) <-- no need for counter
	  (vlax-invoke
				'ParentWindow
		      'ClipBoardData
	    'SetData
	    "Text"
	    pat
Thank you so much!!
dlanorh
I would also remove the (setq vl) bit, as vl is global, never used and might be ambiguous
I am not one of the robots you're looking for
