Sum of attribute values
I've got this lisp routine it works well but I want to modify the result to be in (Mtext) instead of (table) and sum all values in attribute as shown in attached example, Any help please ?
;;---------------------=={ Sum Attribute Values }==---------------------;;
;; This program allows the user to sum numerical attribute values ;;
;; held by a selection of block references, with the results displayed ;;
;; in an AutoCAD table. ;;
;; Upon issuing the command syntax 'attsum' at the AutoCAD ;;
;; command-line, the user is first prompted to make a selection of ;;
;; attributed blocks to process. This selection may include standard ;;
;; or dynamic attributed block references. ;;
;; Following a valid response, the program will iterate over the ;;
;; selection and will sum all numerical attribute values, grouping the ;;
;; values by common attribute tags. ;;
;; If multiple attribute tags hold numerical values, the user is ;;
;; presented with a dialog interface and prompted to select which ;;
;; attribute tags should be displayed in the resulting table, before ;;
;; being prompted to specify an insertion point for the table. ;;
;; The program will then automatically construct an AutoCAD table ;;
;; with properties inherited from the active Table Style. Each row ;;
;; of the table will display an attribute tag alongside the total of ;;
;; all numerical values held by that tag in the selection. ;;
;; If the program is configured to use field expressions in the table, ;;
;; the various totals will be automatically updated following valid ;;
;; modifications to the attribute values referenced by the fields. ;;
;; Note that this does not include the addition of new attributed ;;
;; blocks to the drawing, or the removal of attributed blocks ;;
;; referenced by the table fields. ;;
;; If field expressions are used, the formatting of the results will ;;
;; be dependent on the field formatting code set in the program; ;;
;; otherwise, the formatting of the totals displayed in the table ;;
;; will be dependent on the current unit & precision settings ;;
;; (that is, the values held by the LUNITS & LUPREC system variables ;;
;; respectively). ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Version 1.0 - 2011-01-10 ;;
;; - First release. ;;
;; Version 1.1 - 2015-12-21 ;;
;; - Program entirely rewritten. ;;
;; - User may choose which attribute tags to display in table. ;;
;; - Numerical values of constant attributes now included. ;;
;; - Fields may be used to link attribute values to table. ;;
(defun c:attsum ( / *error* fld fmt fun hed idx ins lst obj sel spc tag ttl val )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(setq
;; Program Parameters ;;
;; Table title (e.g. "Attribute Sum") nil for none
ttl nil
;; Table Column Headings
hed '("Tag" "Total")
;; Use Field Expressions in Table? (t=yes; nil=no)
fld t
;; Field formatting
fmt "%lu6"
(LM:startundo (LM:acdoc))
(if (= 1 (getvar 'cvport))
(setq spc (vla-get-paperspace (LM:acdoc)))
(setq spc (vla-get-modelspace (LM:acdoc)))
(cond
( (not (vlax-method-applicable-p spc 'addtable))
(princ "\nThis version of AutoCAD does not support tables.")
( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
(princ "\nThe current layer is locked.")
( (not (setq sel (LM:ssget "\nSelect attributed blocks: " '(((0 . "INSERT")))))))
( (progn
(if fld
(setq fun (lambda ( obj val ) (strcat "+%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid obj) ">%).TextString>%")))
(setq fun (lambda ( obj val ) val))
(repeat (setq idx (sslength sel))
(setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
(foreach att
(append
(vlax-invoke obj 'getattributes)
(vlax-invoke obj 'getconstantattributes)
(if (setq val (distof (vla-get-textstring att)))
(setq lst (attsum:assoc++ (strcase (vla-get-tagstring att)) (fun att val) lst))
(null (setq lst (vl-sort lst '(lambda ( a b ) (< (car a) (car b))))))
(princ "\nNo numerical attribute data found.")
( (and (setq tag (if (cdr lst) (LM:listbox "Select Tags to Display" (mapcar 'car lst) 1) (mapcar 'car lst)))
(setq ins (getpoint "\nSpecify point for table: "))
(if fld
(setq fun
(lambda ( x )
(list (car x)
(strcat
"%<\\AcExpr "
(substr (apply 'strcat (cdr x)) 2)
" \\f \"" fmt "\">%"
(setq fun (lambda ( x ) (list (car x) (rtos (apply '+ (cdr x))))))
(LM:addtable spc (trans ins 1 0) ttl
(cons hed (mapcar 'fun (vl-remove-if-not '(lambda ( x ) (member (car x) tag)) lst)))
nil
(princ)
(defun attsum:assoc++ ( key val lst / itm )
(if (setq itm (assoc key lst))
(subst (vl-list* key val (cdr itm)) itm lst)
(cons (list key val) lst)
;; ssget - Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
(princ msg)
(setvar 'nomutt 1)
(setq sel (vl-catch-all-apply 'ssget arg))
(setvar 'nomutt 0)
(if (not (vl-catch-all-error-p sel)) sel)
;; ObjectID - Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:objectid ( obj )
(eval
(list 'defun 'LM:objectid '( obj )
(if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
(list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
'(itoa (vla-get-objectid obj))
(LM:objectid obj)
;; List Box - Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
(cond
( (not
(and
(setq tmp (vl-filename-mktemp nil nil ".dcl"))
(setq des (open tmp "w"))
(write-line
(strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
(if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
des
(not (close des))
(< 0 (setq dch (load_dialog tmp)))
(new_dialog "listbox" dch)
(prompt "\nError Loading List Box Dialog.")
( t
(start_list "list")
(foreach itm lst (add_list itm))
(end_list)
(setq rtn (set_tile "list" "0"))
(action_tile "list" "(setq rtn $value)")
(setq rtn
(if (= 1 (start_dialog))
(if (= 2 (logand 2 bit))
(read (strcat "(" rtn ")"))
(mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
(if (< 0 dch)
(unload_dialog dch)
(if (and tmp (setq tmp (findfile tmp)))
(vl-file-delete tmp)
rtn
;; Add Table - Lee Mac
;; Generates a table at the given point, populated with the given data and optional title.
;; spc - [vla] VLA Block object
;; ins - [lst] WCS insertion point for table
;; ttl - [str] [Optional] Table title
;; lst - [lst] Matrix list of table cell data
;; eqc - [bol] If T, columns are of equal width
;; Returns: [vla] VLA Table Object
(defun LM:addtable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid )
(setq sty
(cdr
(assoc -1
(dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle")))
(getvar 'ctablestyle)
(setq hgt (vla-gettextheight sty acdatarow))
(if (LM:annotative-p (setq stn (vla-gettextstyle sty acdatarow)))
(setq hgt (/ hgt (cond ((getvar 'cannoscalevalue)) (1.0))))
(setq wid
(mapcar
'(lambda ( col )
(apply 'max (mapcar '(lambda ( str ) (LM:addtable:textwidth str hgt stn)) col))
(apply 'mapcar (cons 'list lst))
(if (and ttl (< 0.0 (setq dif (/ (- (LM:addtable:textwidth ttl hgt stn) (apply '+ wid)) (length wid)))))
(setq wid (mapcar '(lambda ( x ) (+ x dif)) wid))
(setq obj
(vla-addtable spc
(vlax-3D-point ins)
(1+ (length lst))
(length (car lst))
(* 2.0 hgt)
(if eqc
(apply 'max wid)
(/ (apply '+ wid) (float (length (car lst))))
(vla-put-regeneratetablesuppressed obj :vlax-true)
(vla-put-stylename obj (getvar 'ctablestyle))
(setq i -1)
(if (null eqc)
(foreach col wid
(vla-setcolumnwidth obj (setq i (1+ i)) col)
(if ttl
(progn
(vla-settext obj 0 0 ttl)
(setq i 1)
(progn
(vla-deleterows obj 0 1)
(setq i 0)
(foreach row lst
(setq j 0)
(foreach val row
(vla-settext obj i j val)
(setq j (1+ j))
(setq i (1+ i))
(vla-put-regeneratetablesuppressed obj :vlax-false)
obj
(defun LM:addtable:textwidth ( str hgt sty / box obj tmp )
(if
(and (wcmatch str "*%<*>%*")
(setq tmp
(entmakex
(list
'(00 . "TEXT")
'(10 0.0 0.0 0.0)
(cons 01 str)
(cons 40 hgt)
(cons 07 sty)
(progn
(setq obj (vlax-ename->vla-object tmp))
(vla-put-textstring obj "")
(vla-put-textstring obj str)
(setq str (vla-get-textstring obj))
(entdel tmp)
(if
(setq box
(textbox
(list
(cons 01 str)
(cons 40 hgt)
(cons 07 sty)
(+ (* 2.5 hgt) (- (caadr box) (caar box)))
0.0
;; Annotative-p - Lee Mac
;; Returns T if the given Textstyle is annotative
(defun LM:annotative-p ( sty )
(and (setq sty (tblobjname "style" sty))
(setq sty (cadr (assoc -3 (entget sty '("acadannotative")))))
(= 1 (cdr (assoc 1070 (reverse sty))))
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(vl-load-com)
(princ
(strcat
"\n:: SumAttributes.lsp | Version 1.1 | \\U+00A9 Lee Mac "
(menucmd "m=$(edtime,0,yyyy)")
" www.lee-mac.com ::"
"\n:: Type \"attsum\" to Invoke ::"
(princ)
;; End of File ;;
