Fill / Edit block attributes of a multileader with autolisp
Hi all,
I created a multileader with a attributed block content.
I will use this multileader style in my autolisp with (COMMAND "MLEADER" point1 point2 ... )
I enter point1 point2 then Edit Attribute window pops up on screen.
How can i fill or pass blank these attribute lines in autolisp? How should i continue?
(command "cmleaderstyle" "EI_2.5MM_ATT") ;attribute style selected
(command "mleader"
 point1
 point2 ;after entering two point coordinates what should i do?
Hi @Anonymous
I will use this lisp to create more complex lisps.
pbejse
If you set this two system variable,  Attdia = 0 and Attreq = 1 then you can you supply the attribute values like this
(command "mleader" point1 point2 "1" "2" "3" );<-- the values for the attributes
HTH
ronjonp
Plenty of examples HERE. Newer version HERE.
 That works! Thank you.
