AutoCAD Cleanup Lisp Routine
averys8YKW6
averys8YKW6
I have to clean up 5 to 10 AutoCAD files daily. This becomes a very repetitive task. Is it possible to create a Lisp routine to do this work automatically? I am cleaning up drawings to import into another program so I need to remove all the blocks before, hence the three separate burst commands.
Select All, Burst
Select All, Burst
Select All, Burst
Select All, Overkill  (Tolerance 0.000001)
Select All, Purge All
AECTOACAD
jporter
Somebody already wrote a similar lisp routines here:
If need be, take that and reverse engineer it to your needs.
You can also use this awesome Drawing Purge tool that is free from the Autodesk App Store:  https://apps.autodesk.com/ACD/en/Detail/Index?id=3773138176974634673&appLang=en&os=Win32_64.  I've been using it for awhile and I love it.  It's a "one button does all" tool.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
averys8YKW6
That routine doesn't really look similar at all.
jporter
You need to take what's there and extract only what you need and change the rest.  The command sequence is there though.  Now I'm no lisp genius, but this is what I've done with any lisp routine I've found in the past.  I've also combined lisp routines in the same manner:
Jason Porter
www.asti.com
pendean
Community Legend
Community Legend
dmfrazier
BTW, it certainly isn't "necessary", or particularly advantageous, to use AutoLISP here. A simple script would do, or a menu macro (custom CUI "command").
