File Name in a Dynamic Label View Block
Is there a way to include the root filename for a "view" placed through the Sheet Set Manager? I have my root detail file, with a saved view named "Concrete Paving-6 Inch." The file name is "d-concrete paving-pedestrian." If i use the current filename field place holder in my dymanic view block, it only gives me the file name of the page i place the detail onto, in this case "Hardscape Details."
Any thoughts?
john.vellek
Hi trimbla,
If you were xref'ing in the drawings you might be able to use a diesel expression to get the file name of each xref. Is this something worth exploring?  Otherwise, the drawings once inserted are blocks. Perhaps you could concoct a lisp routine to get the name and view from the block table.
If you want better solutions than I can offer, would you like to move the post to the customization forum?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi trimbla,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Thanks for the reply John. Lets try moving the post to customization and see if anyone has a solution.
Thanks!
