Visual LISP, AutoLISP and General Customization
Extracting the xref file names
6 REPLIES 6
586 Views, 6 Replies
Is there away of extracting the xref file names loaded in a drawing. So that the file names can be printed on the drawing, say using a field. Is there a system variable that this info is stored in?
6 REPLIES 6
I use the rtext from express tools eg .
Xref: $(xrefs,2,Includes: )
I put this on my drawing mask, same again with the plot stamp command :-
ACAD REF: $(getvar, "dwgprefix")$(getvar, "dwgname") $(edtime, 0, MON DD"," YYYY - H:MMam/pm)
If an autoCAD user does not have express loaded on their machine, these functions will only show blank boxes.
Hope it helps
I would not recommend using RText, especially if you are using fields
already. However, there is no field expression that will directly get the
XRefs.
However, there has been code posted in this discussion group in the past
that generates a string or list of the XRefs loaded. You could use that code
to populate a UserSx system variable and use a field to read/display that.
R. Robert Bell
wrote in message news:5418884@discussion.autodesk.com...
scot-65
Cadance,
Here is partial code to find the XRef objects in a drawing.
The file name of the xref is DFX 2, provided the block has not been renamed. Also, the xref name is not sorted if you gather all in a selection set.
(while (setq d (tblnext "BLOCK" (not d)))
(if (assoc 1 d)...
Good Luck!
Scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
A userSx system variable?
What good is that?
It doesn't get saved.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"R. Robert Bell" wrote in message news:5419382@discussion.autodesk.com...
XRefs.
R. Robert Bell
Without RTEXT or a custom field evaluator, there
is no simple way to automate that.
My advice is to avoid RTEXT, as it has been the
source of numerous problems with customization.
You can use LISP code that reacts to events that
fire when xrefs are attached/detached, and then
store and manage the names of the attached xrefs
in a custom drawing property that can be used in
a field.
What Robert suggests (storing it in a userSx system
variable) is really pointless because it is not stored
with the drawing, and can't be used outside of the
drawing editor (e.g., not much different than using
LISP in fields).
Good point. Background publish would have a fit. Document properties is a
better spot.
R. Robert Bell
"Tony Tanzillo" wrote in message
news:5420076@discussion.autodesk.com...
What good is that?
Forma Design Contest
AutoCAD Beta
