I'm getting this now:
Select duct / pipe / cabeltray or fitting:
Wrong object
Below is the object properties that I was able to gather using a script I found. One thing not shown is the CID which is "2041"
The endpoint data is what i'm looking for. I intend use that data to identify shared points for a total count of clamps that we will need for this type of pipe.
Command: HAVEADUMP
Select object:
; IMapsComWrap: IMapsComWrap Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff619731e30>
; Area = 0.621774
; CustomData = "Manufacturer = ,Model = ,Model Option 1 = ,Model Option 2 = ,Model Option 3 = ,Model Option 4 = ,Device Handing = ,Device Tag = ,Device ID = ,CFM / GPM = ,TYP. X = ,Room No = ,Weld Inches = ,Fabrication Time = ,Asset ID = ,"
; Description = "Blucher Pipe - SS-316 [ 2\" ]"
; Document (RO) = #<VLA-OBJECT IAcadDocument 0000019fa7175bb8>
; Elevation = "BOP/I: 13'-10 3/16\""
; EndSize = "Straight 2, Socket 2, "
; EntityTransparency = "ByLayer"
; Handle (RO) = "246E1"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000019fa1697868>
; ItemNumber = "3380"
; ItemServiceType = "Pipework"
; ItemSpoolName = ""
; Layer = "P-WV_N_PIPE_W"
; LengthAngle = 100.506
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; Notes = ""
; ObjectID (RO) = 44
; ObjectName (RO) = "MapsContainer"
; OwnerID (RO) = 43
; PlotStyleName = "ByLayer"
; Points = "ENDPOINTS: 1260.76,802.77,167.39;1361.24,802.77,169.48;"
; Section = "None"
; ServiceName = "W (AG - Blucher SS-316)"
; Status = " 0: Design"
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000019fa16975c0>
; Visible = -1
; Weight = 0.0
; Methods supported:
; ArrayPolar (3)
; ArrayRectangular (6)
; Copy ()
; Delete ()
; GetBoundingBox (2)
; GetExtensionDictionary ()
; GetXData (3)
; Highlight (1)
; IntersectWith (2)
; Mirror (2)
; Mirror3D (3)
; Move (2)
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
