Create a macro to do selection
filapost
filapost
create a command Macro or an autolisp function to select all the dimensions  and put them on a new layer called "dim"
Kent1Cooper
Welcome to these Forums!  Have you tried Searching for one [always the best first step]?  There is probably something like that here already.
Kent Cooper, AIA
hi There,
one way To do This:
(ssget) all of your dimensions
(Then Move to Layer)
I do not have Autocad loaded or installed so I can not check This.
I am Totally new to Fusion360. I am still Looking for the LISP Loader
but, for what it is worth, check This out.
(defun c:DFX (/ BK LA SS N SSL B C)
(setq LA (getstring "\nEnter Layer Name: To Move Dimensions To: ")
(prompt "\nSearching for Dimension(s) ... ")
(if (eq (setq SS (ssget "X" (List (cons 0 "dimensions")))) nil)
(progn
(prompt "\nNo Dimensions found, Please try again.")
(command nil nil nil)
(progn
(setq N 0
SSL (sslength SS)
(DMFIX)
(princ)
(defun DMFIX ()
(prompt (strcat "\nSearching for all Dimensions "))
(while (< N SSL)
(setq B (ssname SS N)
C (entget B)
NEW (cons 8 LA)
OLD (assoc 8 C)
(if (/= NEW OLD)
(setq C (subst NEW OLD C))
(entmod C)
(setq N (1+ N))
(princ "*")
(prompt (strcat "\n<" (itoa SSL) "> Dimensions Moved To LAYER <"
(strcase LA) ">. "))
You might want to check the Line That has the (ssget "X") function in it, To make sure how "dimensions" are actually Listed/named in DXF codes.
It might be possible to ADD a Dimension Style (not sure how To do This) so That You can move certain dimensions to a specified Layer instead..
I hope This is helpful
Randy (just add coffee)
2dcd2b3d@gmail.com
filapost
Hi 2dcd2b3d
Thank you for your time and response!
You were very helpful with your suggestion
I used your code and I only made a change at
"dimensions" to "dimension"
It took me quite a long to find it, but it works perfectly.
Thank you very very much!!!
