Extract a value from a Dynamic block using simple Autolisp code rather than Visual Lisp
peter_thomson
Message 1 of 11
peter_thomson
Hi All,
I see that there are a lot of posts for extracting values or properties from a dynamic block, however, all the code I have seen so far is Visual Lisp. Wondering if it is possible to extract a value from a dynamic block using just simple Autolisp functions. The reason is that I would like to re-jig some useful code that extracts attrributes to build a sensible PDF filename when plotting drawings but it can't be VL code as I want to run it as a script using AutoCAD Core Console. My understanding is that Core Console does not accept VL code....at least, there are no VL commands in the commands list for Core Console.
I would appreciate any advice. Just not sure that it is actually possible.
The code I am trying to replicate is...
;;now get status from separate dynamic block ONLY IF IT EXISTS
(if (/= "" XDYNBLNAME )
(progn
(setq BName XDYNBLNAME)
(setq VLAOBJ (vlax-ename->vla-object (SDynBe Bname)))
(LM:getdynprops VLAOBJ)
(setq XSTATUS XDYNSTATUSNAME)
(setq VSTATUS (LM:getdynpropvalue VLAOBJ XDYNSTATUSNAME))
);p
);f
(if (= VSTATUS "FOR TENDER / CONSTRUCTION")
(setq VSTATUS "FOR TENDER AND CONSTRUCTION")
also some Lee Mac functions..
(defun LM:getdynprops ( blk )
(mapcar '(lambda ( x ) (cons (vla-get-propertyname x) (vlax-get x 'value)))
(vlax-invoke blk 'getdynamicblockproperties)
(defun LM:getdynpropvalue ( blk prp )
(setq prp (strcase prp))
(vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
Many thanks in advance,
Peter T
Replies (10)
Message 2 of 11
pbejse
Look here
HTH
Message 3 of 11
peter_thomson
Thank you, however, there is still some VL code in there.
I will try and replace the VL-remove and the VL-remove-if-not code with simple autolisp. I guess it will be less efficient, but the benefit of being able to run the code in Core Console for plotting will be enormous.
Mant thanks,
Peter
Message 4 of 11
pbejse
You mean these two?
(mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 303 (car x))) elst))
(vl-remove-if-not
	  '(lambda (x) (= (car x) 360))
	  (entget enhancedBlock)
I'm pretty sure you can @peter_thomson , go for it then.
Glad it helps
BTW: What about taking the .Net approach?
Message 5 of 11
peter_thomson
The DotNet approach?
I have not ever ventured into DotNet and I am too old to start now...
Not even sure that I am clever enough to re-write that other code but will have a go anyway.
Many thanks.
Peter
Message 6 of 11
pbejse
Let me know if you hit a snag, we'll be here.
Message 7 of 11
scot-65
Not sure what property you are looking for?
Have you tried:
DUMPALLPROPERTIES
GETPROPERTYVALUE
SETPROPERTYVALUE
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 11
Sea-Haven
There is some info somewhere about load a ARX as part of using accoreconsole. Then VL can be used.
Message 9 of 11
_gile
Mant thanks,
Peter
Are you sure the vl-* functions are not supported by the Core Console? vl functions, unlike vla, vlax or vlr functions, are simple AutoLISP functions.
Anyway, you can use the following function:
(defun gc:massoc (code alst)
  (if (setq alst (member (assoc code alst) alst))
    (cons (cdar alst) (gc:massoc code (cdr alst)))
and replace:
with
(gc:massoc 303 elst)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 10 of 11
_gile
Assuming you want to get all the dynamic property values of a block reference, you can try the following:
(defun GetDynamicPropertyValues	(blockReference / blockRecord xDictionary enhancedBlock elst param name lst)
  (if (and
	(setq blockRecord (getDynBlockRecord blockReference))
	(setq xDictionary
	       (cdr
		 (assoc	360
			(member '(102 . "{ACAD_XDICTIONARY") blockRecord)
	(setq enhancedBlock
	       (cdr
		 (assoc	360
			(member '(3 . "ACAD_ENHANCEDBLOCK") (entget xDictionary))
    (foreach prop (gc:massoc 360 (entget enhancedBlock))
      (setq elst  (entget prop)
	    param (cdr (assoc 0 elst))
	    name  (cond
		    ((= param "BLOCKPOINTPARAMETER")
		     (cdr (assoc 303 elst))
		    ((= param "BLOCKLINEARPARAMETER")
		     (cdr (assoc 305 elst))
		    ((= param "BLOCKPOLARPARAMETER")
		    ((= param "BLOCKXYPARAMETER")
		    ((= param "BLOCKROTATIONPARAMETER")
		    ((= param "BLOCKFLIPPARAMETER")
		    ((= param "BLOCKVISIBILITYPARAMETER")
		     (cdr (assoc 301 elst))
		    ((= param "BLOCKLOOKUPPARAMETER")
		    ((= param "BLOCKALIGNMENTPARAMETER")
		     (cdr (assoc 300 elst))
      (if name
	(setq lst (cons	(cons name
			      (getpropertyvalue blockReference (strcat "AcDbDynBlockProperty" name))
			lst
  (reverse lst)
(defun getDynBlockRecord (blockRef / elst xDictionary blockRep repData blockRecord block)
  (if (= (cdr (assoc 0 (setq elst (entget blockRef)))) "INSERT")
    (if	(and (setq xDictionary (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") elst))))
	     (setq blockRep (cdr (assoc 360 (member '(3 . "AcDbBlockRepresentation") (entget xDictionary)))))
      (setq repData	(cdr (assoc 360 (member '(3 . "AcDbRepData") (entget blockRep))))
	    blockRecord	(entget (cdr (assoc 340 (entget repData))))
      (setq block	(entget (tblobjname "block" (cdr (assoc 2 elst))))
	    blockRecord	(entget (cdr (assoc 330 block)))
To get the value of a dynamic property you know the property name, simply use the getpropertyvalue function:
 (getpropertyvalue blockReferenceEname (strcat "AcDbDynBlockProperty" name))
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
peter_thomson
Thank you all for your responses. Will try and get back to my code this week if I can.
Cheers, Peter
