Export polyline data (area, layer and inner text) to excel
Message 1 of 180
Hello, everyone!
I am searching for a lisp that can find all closed polylines in a drawing and export to excel their following information:
-Area of each closed polyline
-Layer in which the polyline resides
-Text inside each polyline
I have a building plan with polylines enclosing each room and the corresponding room text number also inside the polyline. I am looking for a lisp that can export to excel a table like this:
Text inside polylinePolyline Area (m2)Layer
"Room_1.1"10 m2Room_Layer
"Room_1.2"5 m2Room_Layer
"Room_1.3"5 m2Room_Layer
 -20 m2Floor_Layer
The polylines and room text numbers are located in different layers.
One of the polylines (last row in the table) encloses the whole building which means that there is more that one text inside it. For this single polyline, I only need its area and layer (text not needed).
I am fairly new to lisp creation so any help you can provide me would be highly appreciated!
Thanks in advance!
Replies (179)
Message 21 of 180
pbejse
@Anonymous wrote:
Thank you - but I didn't explain my situation completely.
Thank you for your input in trying to solve my problem.
Your problem is easy, its understanding you're the exact requirement is the hard part. Post a drawing sample and what the table should like.
Message 22 of 180
OK - here is the Autocad drawing and a snapshot of the the kind of table I need.
The drawing is a quick architectural layout of a store plan.
Basically I have labeled store department areas  surrounded with polylines in a drawing. I would like to be able to sect them and have the put int an Excel chart.
I thought my problem was the same as miguelmlas - but now I realize i needed the areas to be in square feet (SF) because my drawings are in architectural units.
Message 23 of 180
devitg
Please change it
area   (vlax-curve-getarea e)
to
area  ( / (vlax-curve-getarea e) (* 12 12))
as the area is given in Inch , divide it by 12 times 12 or 144
Message 24 of 180
pbejse
There you go.
I have not a chance to look at the attachments, but what devtg posted makes sense and should work.
pBe
Message 25 of 180
Thank you pbejse and devitg!
Exactly what I need for my project.
Now I am going to see if I can figure out how to round the square foot numbers obtained in the table to be rounded off to the nearest foot.
Message 26 of 180
I used one of Lee Mac's lisp functions - rounding to the nearest integer - and set the precision to "0" and I got the results I needed.
Thanks again!
Message 27 of 180
wacho31
Hi please help me with code:
I would like to see effects like in attached screenshot.
- single & multiline inside polylines
- precision convert from mm2 to m2 and dot in area change to comma
Message 28 of 180
wacho31
Could you help me solve te issue with code:
screenshot in attachment what I would like to achieve and how it works now.
Message 29 of 180
pbejse
That's easy.
Message 30 of 180
Buzz0m
I'm surprised no body mentioned data extraction? I believe most of your needs can be found in this built in functionality. For the custom calculations you can add extra columns with mathemitical functions just like excel...
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
Message 31 of 180
devitg
Show us a sample.dwg. sad to say acad can not handle screenshot.
Message 32 of 180
wacho31
added attachments,
please help me with this issue.
Message 33 of 180
wacho31
Could you help me?
I attached files. Please help me with tis issue.
Thank You
Message 34 of 180
pbejse
@wacho31 wrote:
Could you help me?
Thank You
Please be aware that the sample files you posted on post# 32 are also available to everyone. no need to attached here again.
See attached file: EPD_vpBe.lsp
command: EDP
Text inside polyline,Polyline Area (m2),Layer,Closed,Handle
Single line 1,215654522.43 m2,obszary,Yes,2E4
Multiline 2 | Single line 5,226734779.63 m2,obszary,Yes,2E9
Single line 2,248440499.89 m2,media,Yes,2E6
Multiline 1 | Single line 3 | Single line 4,610955487.01 m2,obszary,Yes,2E5
HTH
Message 35 of 180
wacho31
Thank You for help, 🙂
- single & multiline inside polylines works perfect:)
Could you check how change also precision to convert from mm2 from drawing to m2 and dot in area change to comma like below:
Single line 1,215,65,obszary,Yes,2E4
Multiline 2 | Single line 5,226,73,obszary,Yes,2E9
Single line 2,248,44,media,Yes,2E6
Multiline 1 | Single line 3 | Single line 4,610,95,obszary,Yes,2E5
Thank you!
Message 36 of 180
CLL_PBE
@wacho31 wrote:
Could you check how change also precision to convert from mm2 from drawing to m2 ...
) 4 ) area (car data) (if (zerop ( logand 1 (cadr data))) "No" "Yes") (caddr data)
to
) 4 ) ( / area 1e6) (car data) (if (zerop ( logand 1 (cadr data))) "No" "Yes") (caddr data)
@wacho31 wrote:
.. dot in area change to comma like below..
Sure you want to do that? You realize doing so will give you unexpected results when you open the csv file other than notepad, the comma may be interpreted as a delimiter.  or even importing the data back to Autocad.
Message 37 of 180
wacho31
Hi, thank you for help. Tomorrow i will check code from you. BTW you have right that if I will change dot to comma i couldn't separate column correcly e.g. in excel. Could i use semicollon for separate all data and then implement comma instead of dot in area? E.g.
Multiline 1 | Single line 3 | Single line 4;610,95;obszary;Yes;2E5
If my proposal  could work correctly could you help me with Code? Thank you!
Message 38 of 180
wacho31
I changed separator from comma to semicolon but I have issue how change dot to comma in area
Multiline 1 | Single line 3 | Single line 4;610.95;obszary;Yes;2E5
Message 39 of 180
wacho31
When i changed separator from comma to semicolon effects after export to csv and open it in excel isn't correct
Message 40 of 180
wacho31
Hi I solved issue with separator. I changed it to semicolon also inside heading line.
To achieve fully effects i need now change dot to comma in area.
