Export polyline data (area, layer and crossed text) to excel
chauthienqui
Message 1 of 8
chauthienqui
Hello, everyone!
I am searching for a lisp that can find all polylines in a drawing and export to excel their following information:
-Area , Perimeter, Layer
-Text that crossed polyline
I am looking for a lisp that can export to excel a table like this:
Form this drawing:
I am fairly new to lisp creation so any help you can provide me would be highly appreciated!
Thanks in advance!
I aslo attach the dwg and csv  files for better understanding
For more information: I attached the lisp "EPD" that was found on this forum but I cant modify the code to get right result as wish.
Replies (7)
Message 3 of 8
Sea-Haven
Maybe confirm with real desired Excel output.
Message 4 of 8
daniel_cadext
I posted a sample in Python here, did it as a quick challenge using Pandas
https://www.theswamp.org/index.php?topic=58813.0
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 5 of 8
chauthienqui
Thank for your helps.
I searched in those post already but still not find the solution.
I have just edited my post for better understanding
Message 6 of 8
chauthienqui
Can I get this lisp? I can test it by myself.
Message 7 of 8
Sea-Haven
I dont use python so as a complete solution what is required ? What needs to be installed ? Example Opendcl needs a file to be loaded from within CAD to work. Maybe post a ZIP with all the answers and some instructions about how to install the Python run time. Like wise what about Bricscad ?
Looks good though 10/10.
Message 8 of 8
daniel_cadext
It’s exactly like OpenDCL. In that the Python runtime in embedded in an ARX module, it's in process and fast
Everything is on GitHub , installers, instructions  all the source code,  samples.
https://github.com/CEXT-Dan/PyRx,  https://github.com/CEXT-Dan/PyRx/releases
Still a work in progress, I plan to make a better installer that installs python, wxPython and the arx
Now, you must install Python, then wxPython, then the arx bundle, hopefully the docs a clear enough
Unfortunately, BRX is too far out of date for this project, which is a bummer,
So, it’s compiled for ARX/GRX/ZRX, sans .bundles for the later
