Explode the blocks inside the blocks
適用対象外
930件の閲覧回数
6件の返信
メッセージ1/7
適用対象外
Dear all,
I am trying that to explode all the blocks inside blocks.
I written a code like below, but i have a doubt that how to repeat the process until end of the blocks ?
(defun c:GAD()
	(if
		(and
			(/= (setq blocks (ssget "_X" '((0 . "INSERT")))) nil)
			(setq ctr 0 len (sslength blocks))
		(progn
			(while (< ctr len)
				(command "qaflags" 1)
				(setq blk (ssname blocks ctr))
				(command "EXPLODE" blk "")
				(command "qaflags" 0)
				(setq ctr (1+ ctr))
	(command "_.PURGE" "_all" "NO" "")
	(princ)
Please teach me how to grow myself in this topics ?
0 件のいいね
931件の閲覧回数
6件の返信
返信 (6)
メッセージ2/7
hak_vz
(defun c:GAD()
	(setvar 'qaflags 1)
	(setvar 'cmdecho 0)
	(while (setq blocks (ssget "_x" '((0 . "INSERT"))))
		(while (< ctr len)
			(setq ctr (1+ ctr))
	(setvar 'qaflags 0)
	(setvar 'cmdecho 1)
	(princ)
Localize variables. Read the code and grasp the logic. If you need explanation ask.
Miljenko Hatlak
0 件のいいね
メッセージ3/7
pbejse
@Anonymous wrote:
Dear all,
Are you saying explode a block ONLY if it is inside a block?
Explode ALL blocks including inside blocks?
What you have posted is exploding blocks currently on the drawing layouts.
if its the former:
Here's a quick demo [ targeting block definition ]
(defun c:demoEx	(/ a)
  (while (setq a (tblnext "BLock" (null a)))
    (if	(/= 4 (logand 4 (cdr (assoc 70 a))))
      (vlax-for	obj
		    (vla-item
		      (vla-get-blocks
			(vla-get-ActiveDocument (vlax-get-acad-object))
		      (cdr (assoc 2 a))
	(if (and
	      (eq (vla-get-ObjectName obj) "AcDbBlockReference")
	      (vlax-write-enabled-p obj)
	  (progn
	    (vla-Explode obj)
	    (Vla-delete obj)
  (princ)
HTH
0 件のいいね
メッセージ4/7
Kent1Cooper
If you're Exploding one at a time, you don't need to mess with the QAFLAGS System Variable, but since it will only Explode one in a (command) function, you also don't need to complete the selection.  And you don't need to check whether the selection set is not nil, but merely whether anything is in it, that is, whether it exists.  Also, the (progn) function isn't doing anything for you.  I would simplify that code [not going after nested Blocks yet] this way:
(defun c:GAD()
	(if
		(and
		(while (< ctr len)
			(command "EXPLODE" blk)
			(setq ctr (1+ ctr))
	(princ)
But in addition, it's not necessary to put each Block into a variable -- they can Exploded right out of their position in the selection set.  For getting all the nested Blocks remaining, until there are none left, I think it can be as simple as this:
(defun c:GAD (/ blocks n)
  (while (setq blocks (ssget "_X" '((0 . "INSERT"))))
    (repeat (setq n (sslength blocks))
      (command "_.explode" (ssname blocks (setq n (1- n))))
    ); repeat
  ); while
  (princ)
BUT it is probably worth also adding a check on whether each Insert object is an Xref, before Exploding it.  That would  involve putting each one into a variable.
Kent Cooper, AIA
0 件のいいね
メッセージ5/7
Kent1Cooper
In fact, if you will have any Xrefs, it's more complicated than to do just that check.  There will be an endless loop, since it will always find more Insert object(s).  There needs to be some way of marking that there was at least one non-Xref Block in each round, so it will stop once there are no more.  I'm thinking about that....
[I'd bet there are Explode-everything-all-the-way-down routines out there for the Searching.]
EDIT:  Here's one way [minimally tested]:
(defun C:GAD (/ go-on blocks n blk)
  (setq go-on T); initial value to enable first search
  (while
    (and
      go-on ; first time or previous round included Explodable Block(s)
      (setq blocks (ssget "_X" '((0 . "INSERT")))); still any Insert objects?
    ); and
    (setq go-on nil); will be set back to T if any Explodable Blocks included
      (setq blk (ssname blocks (setq n (1- n))))
      (if ; not an Xref?
        (= (logand 4 (cdr (assoc 70 (tblsearch "block" (cdr (assoc 2 (entget blk))))))) 0)
        (progn ; then
          (command "_.explode" blk)
          (setq go-on T); marker to search another round
        ); progn
      ); if
    ); repeat
  ); while
  (command "_.purge" "_all" "NO" "")
  (princ)
); defun
Kent Cooper, AIA
0 件のいいね
メッセージ6/7
pbejse
Also to consider attribute blocks, regular explode will set the value to tag names as attdef object. among other things. explodable, lock layers, layouts [ as the code is using command...]
[ Atributes will be converted to Attdef ]
(defun c:GAD (/ _explodeAndDelete aDoc b bn tl)
(defun _explodeAndDelete (o) (vla-Explode o) (Vla-delete o))
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vlax-for ly (vla-get-layers aDoc)
  (vlax-put ly "Lock" 0)
  (vlax-for b (vla-get-blocks aDoc
    (cond
      ((vl-every 'zerop
		 (mapcar '(lambda (v) (vlax-get b v))
			 '("islayout" "IsXRef")
       (vla-put-explodable b :vlax-true)
       (Vlax-for c b
	 (if (eq (vla-get-ObjectName c) "AcDbBlockReference")
	   (_explodeAndDelete c)
      ((minusp (vlax-get b "islayout"))
       (vlax-for obj b
	 (if (And
	       (not (vlax-property-available-p obj 'Path))
	   (_explodeAndDelete obj)
 (repeat 4
  (vla-purgeall aDoc)
  (princ)
HTH
0 件のいいね
メッセージ7/7
pbejse
(Defun c:GAD (/ Xrefs a filter blocks n)
    (if	(= 4 (logand 4 (cdr (assoc 70 a))))
      (setq Xrefs (cons
		    (cons 2 (cdr (assoc 2 a)))
		    Xrefs
  (setq	filter
	 (if xrefs
	   (append '((0 . "INSERT") (410 . "Model") (-4 . "<NOT"))
		   Xrefs
		   '((-4 . "NOT>"))
	   '((0 . "INSERT") (410 . "Model"))
  (while (setq blocks (ssget "_X" filter))
    (command "_.explode" blocks)
  (princ)
0 件のいいね
